Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-11-2007, 11:36 PM
newguy2007 newguy2007 is offline
Best manual boost controller?
What is the best manual boost controller for this car? How much horsepower do you think it will add?
http://cgi.ebay.com/ebaymotors/Mitsu...ayphotohosting
there is 160 psi in all 4 cylinders. Look at the description for the rest of the upgraders.
Old 09-11-2007, 11:53 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Best manual boost controller?
The description doesn't say what boost he is running nor how much power it has now. My guess is that if he is smart enought to put the 6-bolt in there he has it tuned pretty good on pump gas and your not going to get a whole lot more out of it.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-11-2007, 11:55 PM
He said if i put the boost controller in there it should get about 330hp. You think its bullshit?
Old 09-12-2007, 12:17 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Well, I doubt you can get 330 with just the SAFC, I think you will need ignition adjustments before that kind of number can be achieved. As for the brand, I have heard rave reviews about JoeP's MBC, $45 and they work great. Thor's rockin one .
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 09-12-2007, 07:05 AM
What is the safc?
Old 09-12-2007, 07:14 AM
Holset powered 420a
Super air fuel controller, Its what he is using to tune the car with.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-12-2007, 10:33 AM
Eclipse4ever's Avatar
Eclipse4ever Eclipse4ever is offline
I think he has a boost controller already. No way he did engine swap and turbo upgrade and whatnot and he has no boost controller. Also turning the boost up will not be the way to make horsepower. He has a EvoIII turbo with 680, you must use the safc to compensate. 680's are a little to big for 20psi on that turbo. I know that on pump gas you can get around 20psi on that turbo before you start knocking. Car is around 300hp.
1997 Eclipse GSX
Old 09-12-2007, 11:26 AM
Thor06's Avatar
Jizzed In My Pants
If he has a pretty freaking good tune. Please dude, tell me you are going to at minimum familiarize yourself with this stuff before you buy a car and start expecting power. That is an excellent way to mess your shit up and be out a LOT of money.
Old 09-12-2007, 11:35 AM
Holset powered 420a
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-12-2007, 03:49 PM
He said i would need to buy a boost controller for more hp so i dont think he has one. He said he is running 12psi and he said about 290 horsepower right now. He said if i had a boost controller i could probably get 330.
Old 09-12-2007, 04:19 PM
XeVeNskyLiNE's Avatar
XeVeNskyLiNE XeVeNskyLiNE is offline
Turbo makes me emo!
Send a message via AIM to XeVeNskyLiNE
Oh craps....
If you're new to DSM's or anything turbo'd, I'd say stick with the 290hp its supposedly coming with before you crank up the boost and not knowing what other things that go in hand with "simply" adding more boost. Although it seems with the injectors, with a proper tune it COULD handle a bump up, no prob.
As for the MBC, I have a BoostScience MBC in my 240, but I don't even touch it because I myself am a bit of a turbo newb, plus I need 550cc injectors and a dyno tune, argh....
9psi = training wheels.
_______A-10 Aircraft Armament Systems Apprentice vv Can't get my sig right vv
Currently in Davis-Monthan AFB, Arizona MySpace My S14 and DSM
Old 09-12-2007, 05:04 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Doesn't look to bad. But I doubt that car has 290hp.
1991 GSX 2.3 Stroker
Old 09-12-2007, 06:16 PM
Thor06's Avatar
Jizzed In My Pants
Yeah, power isnt as easy to come by as people think it is. Honestly, I would be pretty suprised to see that car put down more than, fuck I dont know, like mid-low 200's. My best guess would be between like 225ish. Its definately not 290 with just 12 lbs of boost.
Old 09-12-2007, 08:57 PM
Cant i just turn the boost up? With all the performance shit on the car could i turn it up to like 17 and what hp would i get from that?
What other performance parts would u reccomend i put on there?
Old 09-12-2007, 09:38 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Really, you need to research this subject alot further. There is alot of good information out there.
No, don't just go cranking up the boost just because you have the mods. You also need to tune it. Either buy a wideband to tune yourself or take it to the dyno and have them tune it. No clue what 17 psi would make on the 16G, but I can tell you 12 psi is definately not making 290 to the wheels. Also beware of that boost creep, them 16g's love doing it.
I could recommend so many performance parts, but I have no idea what your goals are. But I would have to say get some cams that was probably my favorite mod aside from the turbo.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
