| Cavalier Problem Diagnosis Got a problem you can't fix? We can help. |
When I have my foot on the brake and shift to Drive or Reverse, Ill sometimes get a hard clunking along with I guess call it a clinking noise. Does it in Reverse and Drive. Everything seems ok when driving normally.
I have a 1999. Can it be low on tranny fluid? Its hard to check because of course no dip stick. But rather have to unscrew the screw on the side, near the exhaust pipe and see if oil level is ok. Whats wrong with the designers on this particular car! Anyway, can't even get the normal oil change people to just service the tranny with changing the fluid. Its been about 40,000 miles since fluid been changed. Any suggestions what it could be. Just started. Thanks |
Re: Transmission Noise?
but like u said its guna be kinda ard to check it without a dipstick |
Your motor mounts or trans mounts could be bad. Best way to check is to lightly power brake the engine while someone else watches the movement of the motor mounts. It should be pretty obvious if they are bad. Not sure? Take it to a friend/mechanic that you know. Takes all of 10 sec to diagnose.
How do we even change the transmission fluid on these things...??
z24forlife
bad motor mounts usualy just give you bad torque steer when you accelerate |
The complaint isn't about shifting problems, it's about a clunking noise when he puts the car into gear with the brake on. A bad motor or trans mount can absolutely cause that.
Oh, and if you think checking the fluid on a cav is a PITA, try a VW or BMW - those engineers either have a bad sense of humor or they were very drunk when they designed those ones. |
Sorry to intrude... but i managed to check to trany oil by un-screwing the drain screw... oil was pissing out.. so the level is fine... The guy also told me that the oil looks pretty clean... but Ill change it soon... next month when i get the cash..
z24forlife
Of all the things, I changed the MOTOR oil and the sound is less? Weird. I let the oil change go a little longer than normal. I went about 3,500 miles instead of the normal 3,000 miles. Doesn't make sense. Probably just coincident. I'll have to jack the car up level like the Haynes manual says and open the check cap at the side. Or I may just change the tranny fluid. How many miles should it go before changing? I put alot of miles on this beast, about 3,000 a month, so it probably is a good idea. Any recommended fluid to run in the tranny6.
Oh for motor oil, Ive used Castrol Semi synthetic 5W-30. Seems just fine. |
