Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 09-11-2007, 01:21 PM
BostonKev BostonKev is offline
2001 3.8 pwr steering question
Hi All, recently my power steering reservoir appears to keep losing fluid and I haven't had a chance yet to get under it and make a real diagnosis. Car has 122k. My questions are is there a common point of failure in the either of the lines and I see that there was a TSB about it (Bulletin No.: 06-02-32-013) and I'm curious if this is a possible recall issue. Thank you
Old 09-11-2007, 03:24 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 2001 3.8 pwr steering question
If the p/st shaft seal has gone bad, it will fling fluid around the belt area and coat teh front of the engine with fluid. The other common failure point is the rack and pinion itself, either the seal where the steering column hooks in, or where the inner tie rods hook in.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 09-12-2007, 11:14 AM
are there any recalls associated with the TSB?
Old 09-12-2007, 03:11 PM
maxwedge maxwedge is offline
A990 racer
Check with a Chevy dealer, give them the VIN.
