Old 09-11-2007, 12:39 PM
Boosted1 Boosted1 is offline
Electrical failure?
So I have to pick up my wires & plugs next weekend and see if that does anything for the horrible mis/backfiring. As soon as I even touch the gas the car dies.
Anyway, last night I started it for a few minutes and this time (battery just charged) after running for a few minutes my headlights started to dim, clock started blinking, and gauges dimmed. I don't think the battery is bad and the alternator is fairly new. Could this be a bigger problem related to the ECU or anything like that, perhaps causing the backfiring also? Of note, I took apart some hoses, the intake (filter looks good), and such the other night for the first time ever. Need to learn how to work on the car as no one else seems to know how.
1993 Mitsubishi 3000GT VR4 (STOCK)
1989 5.0L Ford Mustang (MODIFIED)
http://www.cardomain.com/memberpage/761789
Old 09-11-2007, 06:43 PM
Hotshot8792 Hotshot8792 is offline
Re: Electrical failure?
well, seeing as you have a 1st gen, do step #1 and make sure the capacitors in your ECU haven't leaked
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 09-12-2007, 08:58 AM
I see capacitors for sale all the time on ebay for like $5. Should these do the trick?
Old 09-12-2007, 03:04 PM
first of all, check and see if that is the problem. Open up your ECU and look to see if it looks messy around the capacitors on the circuit board. No use buying capacitors unless that is indeed the problem. Electrical problems are sometimes tough to find.
