Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-10-2007, 09:50 PM
newguy2007 newguy2007 is offline
130 from a GST??
Ive heard that the eclipse GST will cut out at 130. Is this just on the stock gst?
If i add performance parts can it go over 130?
BTW, i dont plan on going over 130 ever but im just curious.
For example, do you think this car will do over 130?
http://cgi.ebay.com/ebaymotors/Mitsu...ayphotohosting
Old 09-10-2007, 09:57 PM
steviek's Avatar
steviek steviek is offline
Re: 130 from a GST??
speed limiter but yes they can go 130
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 09-10-2007, 10:10 PM
Can it go OVER 130 with boost, cai, and other performance parts?
Old 09-10-2007, 10:17 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
The car has an electronic speed limiter on it around 137mph I think. If you dissable that then yes you can go faster.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-10-2007, 10:31 PM
How do i disable it?
Old 09-10-2007, 10:35 PM
Gsst98's Avatar
Gsst98 Gsst98 is offline
Send a message via AIM to Gsst98
its just over 130 i think its 132... is there really a point to go that much faster
Old 09-10-2007, 11:21 PM
Holset powered 420a
You have to open up the ECU and take out a resister if I remember that right. Search and you should be able to find it. Try VFAQ.com
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-10-2007, 11:31 PM
MazdaX's Avatar
MazdaX MazdaX is offline
i've hit 135 in my rs going downhill =D well...down parley's canyon actually lol.
but most built in speed limiters can be disabled with a external wire being clipped , throw on a toggle switch because for osme odd reason it usually trips the CEL light , did on my mx-3 and on my mazda 6 i. :/ but if you toggle it you can turn it on and off at will for things like emissions and inspection.
2004 Mazda 6i
1997 Tahoe
Old 09-10-2007, 11:36 PM
Holset powered 420a
The rs and gs dont have speed limiters. They dont have enough power to get up that fast. Neither do the gsx I dont think. And its all in the ECU unless you put a switch on the speed sensor which would kill your speedo to and throw off your odometer.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-10-2007, 11:44 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 09-10-2007, 11:49 PM
[quote=l_eclipse_l]
STOP...MAKING....DICKHEAD...COMMENTS!!
Old 09-11-2007, 12:40 AM
MazdaX's Avatar
You can get a 1980 S-10 up to 130 going down parley's..it's insanely steep. one of the steepest canyons in the country I believe.
2004 Mazda 6i
1997 Tahoe
Old 09-11-2007, 06:33 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Why would they do it to just the GST? That doesn't make sense... But I'm not disagreeing with you, cause I actually think that is correct for some reason... My TSi AWD has seen 140 with no cutoff so who knows whats up with that... I was scared to go any faster than that, also the fact that its just plain stupid. (Back when I first got the car for anybody wondering)
Oh, and |_eclipse_|... Just chill dude... Seriously... I don't feel that this thread is out of line for a serious answer. He was asking a legit question about the speed limiter and if performance parts will push it past that limit...
The answer is yes, performance parts will give it the umph it needs to get past 130 granted the speed limiter has been removed/disabled... But you must realize that its there for your safety. Also note that your tires are probably not rated to go over 130 unless you replace them with a higher grade of tire...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 09-11-2007, 07:53 AM
Holset powered 420a
I dont get it either but my car has seen 140 also and that thing never cuts back. The only reason you should remove it is if you getting that high of a trap speed at the track, which we all know your not going to unless your putting down an ass of power.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-11-2007, 10:05 AM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
The reason that the GST has a limiter on it is because it normally didn't come with Z rated tires thus the tires were unreliable at high speeds. The GSX came with Z rated tires, and well the GS and RS, that just speaks for itself.
I'm pretty sure what I just said is on VFAQ as well.
1991 GSX 2.3 Stroker
