Go Back   Automotive Forums Car Chat > Honda > MDX | Pilot
Old 09-10-2007, 01:12 PM
camster camster is offline
New, bigger Pilot tires?
Anyone swapped out for a larger SUV tire? I'm looking at a 245 or 255 SUV tire (Dueller or Scorpian).
Questions are (1)will a 245/255 fit and (2)can the Pilot suspension handle a tire that is 10 to 13 pounds heavier? Current tires are 27lb each and new are 36-40lb.
My 2007 Pilot came with a sad set of GoodYear Integrity car tires - 235/70 R16. These tires are scary on wet roads.
Thanks
Old 11-28-2007, 09:11 PM
elvin331 elvin331 is offline
Re: New, bigger Pilot tires?
www.tires.com would tell you what size tires will fit your vehicle.
Old 01-09-2010, 10:08 PM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
I just picked up a 2004 Pilot and have been debating the same thing, what size to go with. Luckily my 235x70x16 are truck tires. If you go to www.1010tire.com they have a size calculation tool there that shows the percentage difference from your original size to the ones you want to go to. I believe rule of thumb is no more than 5% difference. It will also show you the difference in the speedometer readings.
Good luck!!!
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
