Old 08-22-2007, 07:48 AM
arnea arnea is offline
1992 buick lesabre limited
Good morning: I several issues with this car that has 191,000 miles on it. Great Car!!!!! 1. Losing coolant slowly, is this engine suseptible to gasket failures as the 3800II engines???? 2. Drivers door does not lock sometimes intermittent power actuator??? 3. A/C air is cold enough but the blower volume is insufficient have replaced blower motor and it seems to run at full speed 4. Code 41 cam sensor postion fault. Is it more likely with 191,000 miles on it that the magnet has fallen off than a bad sensor???? Thanks Arne
Old 08-22-2007, 10:51 AM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Re: 1992 buick lesabre limited
Welcome to AutomotiveForums, Arnea!
1)The series one motor never had the head gasket problems it's successor did, but I wouldn't rule that possibility out. About how much coolant are you losing? How often do you need to refill?
2)The lock actuators in these car are VERY prone for failure, I've had my share of experience with them . They cost between 30-70 dollars new, depending on the brand and where you buy them, but I got 2 from the junk yard for $25. FYI, the actuator is the same for both front and back doors as long as they are from the same side of the car.
3)Check vaccuum hoses (the vaccuum pump is the black box on the firewall right next to the master cylinder) I recently found that the insufficient airflow in my '92 was due to a deteriorated blower box, the housing where the blower motor attaches to had moisture build-up underneath and the plastic finally just crumbled at the very bottom. (I'm guessing that the drain hole got clogged and the condensation just stayed trapped inside the box) I rolled underneath the car with the A/C on and I felt the cool air blowing right out of the damaged area (appx. 4in x 1/2in crack!) I tried using a tube of black silicone for a makeshift repair, but I felt only a slight improvement
4)My '92 got the code 41 about 3 years ago, it had somewhere around 146,000 miles at the time. With that many miles, it's highly advised that the sensor, magnet and timing set (chain and sprockets) all be replaced at the same time. With 191,000 on your car, if you have never changed the timing set before, it's time to, now! Typically the 3800 is due a timing set change at 150k, so yours has lasted a good while!
Good luck with everything!
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 08-22-2007, 12:26 PM
Thanks LoeKee 75: The coolant leak is slow but it is there. I loose the entire coolant overflow and some of the radiator level over 1 thousand miles. Can it be the intake mmanifold gaskets????? Also do you have to drop the oil pan to get the timing cover off????? Thanks Arne
Old 08-22-2007, 12:59 PM
ChemMan ChemMan is offline
The coolant leak is due to the lower intake manifold gaskets breaking down and allowing coolant to leak into the engine. The series 1 gaskets are made the same way as the series 2 (but not interchangeable), so they have the same problems. Make sure you get a new plastic coolant elbow before you pull the manifold, as your chance of breaking the old one is about 99.9%. You want to do this soon as antifreeze in your oil is very bad for you bearings!
You don't need to drop the oil pan to remove the front engine cover, just a few oil pan bolts.
2010 Mazda CX-7 2.5L 12000 miles
2003 Chevy S10 Extreme 4.3L 57000 miles
1995 Buick Lesabre Custom 86000 miles RIP
2002 Pontiac Sunfire SE 130000 miles RIP
1997 Pontiac Bonneville SE 91106 miles Totaled by attempt to steal the car!!
R.I.P. 1978 Ford Fairmont 83000 miles
Old 08-23-2007, 04:15 AM
Loekee75's Avatar
Have you thoroughly inspected your radiator, and all cooling system hoses for leaks? A small leak can simply run along a hot radiator, hose, or anywhere around the block where the hoses connect, and evaporate before even dripping to the ground. Don't assume the head gasket is blown until you cover all the bases first. In 1,000 miles, in my opinion, a slow but present EXTERNAL leak may be present and could cause the loss of coolant you're experiencing.
Old 08-23-2007, 03:49 PM
Totes Totes is offline
Is the motor oil discolored? Does the exhaust have a "sweet" smell to it? Did you check under the carpet, passenger side floor pan, for coolant possibly heater core?
Old 08-23-2007, 04:25 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
1st, the Vin-L 3800 in your car doesn't have the problematic coolant elbow or intake gasket design that the vin-k 3800's do. The coolant leak is probably due to the plastic screw-in hose nipple that comes out under the alternator or the water pump bearing has failed and it is leaking out the "weep hole" in the water pump casting.
The code 41 could be either, but I'd bet it's the magnet not the sensor.
The timing cover can be removed without dropping the oil pan, but since it's a relatively simple job (nothing in the way), I'd replace the oil pan gasket (a weak point on these engines) while I had the timing cover off if you're keeping the car. You'll also need a special harmonic balancer puller to get the timing cover off.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 08-27-2007, 10:37 AM
crankshaft position sensor
Can you replace the sensor without using the special postioning too GM J37089???Thanks Arne
Old 08-27-2007, 10:54 AM
richtazz's Avatar
Re: crankshaft position sensor
yes you can, but you're taking a chance of it getting munched up by the harmonic balancer. With an assistant, you can get the sensor positioned so it has an equal size gap on each side of the reluctor (part of the balancer), then have the assistant tighten the nut from the bottom. I know of people whom have used a narrow strip of paper folded to get the right thickness, tehn shoved in the gap, and tightened the sensor themselves, but that is a frustraing way to attempt it.
Old 08-27-2007, 11:11 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Rich brings up a good point but I heard you can use a rubber band on the early 90's 3800 VIN "L" engines pre Series I and II according to our GM resident expert. BTW - Seriously. See link below.
Click here
Timeslip 08/12/06
AF Community Guidelines
Old 08-27-2007, 11:44 AM
Thanks for the reply guys... Does the tool exist anywhere??? Also the car has 192,000 miles on it. Would it make sense to replace the harmonic balancer while i have it off????Thanks AQrne
Old 08-27-2007, 11:56 AM
BNaylor's Avatar
Probably not a bad idea to replace the harmonic balancer. As far as the special tool new costs around $350 plus. You may be able to find a used one on EBay.
All the J37089 special tool does is help center the sensor and so there should be no effect on timing if you decide on going with the cheaper alternative methods described above.
Timeslip 08/12/06
Old 08-27-2007, 12:02 PM
$350 buys a lot of rubber bands...Thanks Arne...... PS. I am going to replace the timing gears and chain and cam sensor while I am in the area. Does anyone know if the cam sensor magnet comes with a replacement timing gear or do I have to purchase it separately??? Anything else I should replace????The waterpump is fairly new...Arne
Old 08-27-2007, 09:07 PM
spinne1 spinne1 is offline
Firstly, buy the timing chain and gears. I can't remember if it comes with the magnet. Open the package at the auto parts store and look. If it comes with it, good. If it doesn't, just say, "oh, and one more thing...."
Old 09-10-2007, 07:40 AM
order the timing gear set and the magnet does not come with the gear...Arne
