Old 09-10-2007, 07:19 AM
anopanjo anopanjo is offline
Send a message via MSN to anopanjo
Distance!
Hey sorta dumb question but how far are you meant to spray models, as in how far should the can be from the model?
Roughly..i think im to close...
Old 09-10-2007, 07:31 AM
AllAlone.Gz's Avatar
AllAlone.Gz AllAlone.Gz is offline
Re: Distance!
Hmm. I think that varies on different people.
What do you consider as "Too close" and "Too far?"
I spray my models on a stand that rotates and hold the can about a foot away. Although I spray many light coats rather than like 2 or 3 wet coats. If it works for you keep doing it. Don't give up something that works and end up messing up a kit.
'99 Honda Civic Hatchback-R.I.P May 04, 2010
NikonEquipped.
Flickr.com/photos/oneohnine27
OneOhNine27*
Old 09-10-2007, 07:36 AM
cyberkid's Avatar
cyberkid cyberkid is offline
Re: Distance!
This is one of those things you have to figure out for yourself.
Abing: 1-6 inches.
Detail Abing: under 1/2 an inch
Can spraying cold: 4-6 inches
Can spraying hot: 6-12 inches
Please read the following linked articals before posting a question.
Once you have and still have questions, try to post your questions clearly.
This will make a lot of people's blood pressure drop back to normal, including mine.
NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST
AF Car Modeling Tutorial, How-To and Product Review Depository
AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0
And finally,I wish you all happy modeling
Old 09-10-2007, 08:04 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: Distance!
Spray distance is a good question, but really it's the wrong question.
The real question is "how much paint should I be spraying on at a time?" or "how do I get the right amount of paint on at a time?".
Spray distance is certainly one variable, but it's certainly not the only one. Can pressure, temp, and trigger pressure all effect paint flow as well. A distance that works great at one can pressure can be completely wrong at another.
The best answer for the above questions is to watch the body as you're painting it and see how the paint is going on. Paint in good light and watch what the paint is doing. You can certainly see when the paint is going on too heavy- and you can see when it can be applied a bit heavier.
Light coats are always better than heavy wet coats- so always err on the side of too little, instead of too much. So start further back than you might expect to, and watch the paint as you're applying it to tell how close your spray distance should be.
PHOTOBUCKET SUCKS
