Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-10-2007, 03:40 AM
firestarter69 firestarter69 is offline
Angry Crank shaft pully
After my power steering belt broke it took out the alt. belt. I went to replace it and noticed that the Crank shaft pully is now against the frame and doesnt move. WTF does this mean?
Old 09-10-2007, 08:32 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Crank shaft pully
That's nearly impossible to happen. Is it a new pulley? Ya they sit close, but there's about 1/2 inch inbetween the 2.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-10-2007, 10:31 AM
flyguy123 flyguy123 is offline
Is it fully seated on the shaft? Maybe broken motor mount?
Old 09-10-2007, 10:38 AM
david-b's Avatar
Dave is THAT guy
Can you post up a pic showing this? Like from a good angle showing everything. Thanks.
75 Monte Carlo
Old 09-10-2007, 10:39 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Im guessing a motor mount broke. This should be very obvious since the motor would be leaning bad
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-10-2007, 10:49 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Yeah dude, that sounds crazy as hell. A picture would be great, this is pretty confusing to me. Pulley bent maybe? I'm not sure if missing a mount will allow it to lean that far. At the same time, how would one bend a fuckin underdrive pulley?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 09-10-2007, 12:54 PM
david-b's Avatar
Dave is THAT guy
Those things are impossible to bend. You ever try? They're solid metal.
Even if it was off-centered, it still couldn't hit the frame.
If the bolt going down the center to the crank was off/loose, you would hear and have busted the belts long time ago. Those are nearly impossible to just come loose and pop off. I had to crow bad mine off. Wasn't easy. And that was already it was off a couple years back for replacing. If it was loose and rubbing, you would see wear on the frame itself where it's against. Is there damage there?
Even with a broken motor mount, I don't think the pulley could touch the frame. If you lost the front mount (pulley side), the tranny mount will still be holding the engine straight. If any of the rollers broke, the engine still wouldn't move. Ya there'd be more give in the motor, but not enough to move it over those couple inches.
This isn't making sense to me. We really need pics here.
75 Monte Carlo
Old 09-10-2007, 01:13 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
No way a broken motor mount would cause the engine to move significantly, muchless bend a pulley.
I don't see how this is possible, and without pictures it's hard to tell what the guy is talking about.
1991 GSX 2.3 Stroker
Old 09-11-2007, 10:19 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
I'm guessing that the crank bolt has been gone for awhile and the pulley spun on the crank long enough it loosened it up and worked itself off. You need to put the pulley back on and re-install the bolt that goes down the center of the crank. Then get new belts and drive your car.
EDIT: Are we talking about a turbo or non-turbo, and what year?
95 Talon TSI AWD
97 Eclipse GST
Old 09-11-2007, 10:57 PM
Holset powered 420a
I assumed it was the 420a
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-11-2007, 11:13 PM
That's what I assumed too.
95 Talon TSI AWD
97 Eclipse GST
Old 09-27-2007, 10:22 AM
Sorry its been so long. I went to jail for the last time I was racing my car. But I'll see what I can do about posting some pics. Nothing seems broke but the pully is pushed against the frame and bearly moves. Theres no play back and forth or side to side. I'm afraid something blew inside the engine but I dont have the resources to fix this piece!!! I hate this car with a passion. I've had nothing but problems. Its not like I can trade it in either.
Old 09-27-2007, 10:37 AM
david-b's Avatar
Dave is THAT guy
Ahh, the reason why we don't race.
You didn't blow anything on the inside. The only way that the crank pulley can be pushed out and have some inside wrong would be like a broken crank shaft... but that doesn't happen.
75 Monte Carlo
Old 09-27-2007, 11:09 AM
Thor06's Avatar
Jizzed In My Pants
The other reason we dont race. What the hell did you expect homie? Obviously you race a lot, I dont believe for a second that you went to jail for racing just once. Racing a car thats been abused and neglected, breaking down is just whats going to happen and yeah it sucks but its not the car's fault.
Old 10-13-2007, 01:22 PM
Hope these pics help. Cause I have no idea what to do now. I tried to start it and it would crank but not turn over. Like theres no spark or fuel.
