Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 09-10-2007, 01:05 AM
2001impala 2001impala is offline
Exclamation 01 impala 3.8L Clogged CAT
2001 impala 3.8 L 122,000 miles. Had the car checked out catalytic converter is clogged. Car drives rough cant go over 55mph..struggles from 30-40mph.
Any recommendations. should i just replace the cat? is it an expensive job? is it just the cat or another pipe attached to it? can the cat be cleaned out, is there any kind of solution or liquid that can clean the exhaust out. is there anything the dealer can do? i bought this car used, is there a warranty or not anymore? thanks
Old 09-10-2007, 08:34 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: 01 impala 3.8L Clogged CAT
I believe there is an extended warranty (something like 10yrs/120k or 8yr/80k) that GM has instituted for certain year Impalas because the converters went bad early. Someone else might be able to elaborate further on this .
EDIT: This link might help :http://www.epa.gov/otaq/consumer/warr95fs.txt
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 09-10-2007, 10:53 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Call your Chevy dealer with your vin, and they will be able to tell you if your car qualifies for the extended warranty. Since you are just over the 120k mile mark, if you pitch a bitch, they should do it for free.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 09-11-2007, 09:03 PM
Gems Gems is offline
The extended GM warranty on the bad CAT is 10 years/120,000 miles...
Go Mark Martin!
Old 11-23-2007, 09:23 PM
truechevyman truechevyman is offline
you are correct on everything. i had the same problem with my 2002 impala. At the time i had 110km and i got there just in time. I hope this helps.
truechevyman
