What do ya'll think is sufficient time running (or miles) with 1 quart of SeaFoam in the crankcase (in the engine oil) to DEFUNK the gummed up engine of a 95 Windstar 3.8L with 157k miles?
I want to make sure I get it good n cleaned cause I'm pretty sure its gunked up. I put in some engine stop leak (best brand I could find) and I did so against my will as I always advise not to use the stuff, but I was pressed for time and had to haual a load and needed to make sure I had no leaks during the trip. Since then the engine has seemed to struggle to stay running especially on start-up after being cold. After it warms up though it does ok although I have to rev it at first to get it out of its struggling phase. Though today as I was sitting in a drive-thru it just flat out killed on me twice with NO indication it was about to. It was very abrupt. I'm going to pour SeaFoam in the intake in a separate cleaning too after I've drained the engine oil with the gunked seafoam in it.
1995 3.0L 3000GT NA FWD ATX - ProwlerGT on 3si.org 1995 3.8L Ford Windstar GL -------------------------------------------------------------------------- "I drive the newest 1995 Ford Windstar anywhere..... when its not broken." |
Re: Sufficient Seafoaming process for 95 3.8L?
After you do this change the plugs.
I have found that when you clean up an engine sometimes it will foul the spark plugs.
Thank you for letting me know. Unfortunately I have no clue as to how I'd get to the rear bank. I guess I could check the front bank plugs after the seafoaming and see how they look to judge if I should replace them.
But is anyone gonna answer my question? What do ya'll think is sufficient time running (or miles) with 1 quart of SeaFoam in the crankcase (in the engine oil) to DEFUNK the gummed up engine of a 95 Windstar 3.8L with 157k miles?
Well, since this thread didn't really help here is the official answer from SeaFoam headquarters that i received in email today:
HTML Code:
<hr>
A Can of Sea Foam, ( Pint, not a quart), will treat up to 10 quarts of oil, and you probably need only 1/2 can per application. Using more will not allow it to work better, it will only waste the Sea Foam. If the engine is a gunked up with sludge and crud as you think, I really do not think Sea Foam, ( Or any other engine flush) will work. You probably should pull the Upper and Lower Pans and actually clean the stuff out. It probably now is a full fledge mechanical problem, not just a varnish build up. If you want to try it anyway, - Put 1/2 can into the motor oil crankcase, and then drive it normally from 25 to 200 miles. Then change the oil and filter. Put the balance 1/2 can into the fresh oil and "WATCH" it. Putting a cleaner into the oil probably will make the oil dirtier quicker than your normal oil change interval. SO - WHEN THE OIL IS DIRTY - CHANGE IT ! Hope this makes sense. HTML Code:
<hr>
