Old 09-09-2007, 10:08 PM
phrenic13's Avatar
phrenic13 phrenic13 is offline
Thumbs down NO START (no bus)
this was pretty random. dont think its the cps. thought it was the fuel pump at first, but then we noticed something. the voltage, fuel, oil pressure, and temp are not reading when the key is in the on position. after a couple of minutes in the on position the check engine light comes on and the mileage reads "no bus". guess its either the computer or something to do with the computer. i will let everyone know when i find out more about it. in the mean time, give me your opinions.
Old 09-10-2007, 11:02 AM
2000izusu 2000izusu is offline
Re: NO START (no bus)
my vote is for your cps and i have proof! when the pcm comes on it checks the conditions of all the sensors. if any aren't up to snuff you will get a no bus. now the fact that you have a no bus with no start is resulting from the fact that the pcm is checking the cps. when it checks the cps and finds it is a dud the pcm will not energize the asd relay which in turn energizes the injectors and the fuel pump relay. the link below is from a different forum with two people that had the same problem. cps fixed it. click on the link and there is also a link in the link with another similiar situation. mike
http://www.jeepforum.com/forum/showthread.php?t=450966
2006 liberty 3.7 6speed manual
1999 cherokee classic 4.0L
1991 wrangler yj 2.5L
2001 caravan 3.3 auto
1995&1992&1994 camry 2.2L SOLD
1991 silverado 1500 SOLD
2000 rodeo SOLD
Old 09-10-2007, 01:28 PM
phrenic13's Avatar
i was at my friends shop this morning with it and we were tracing down everything trying to find a bad ground, etc. no fuel pressure, no spark, everything was getting power. turned out the CPS is bad and causing the computer not to communicate to anything else.
BINGO!!!! good job
another one gets bit by the CPS bug
Old 09-11-2007, 08:39 AM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Phrenic13, thanks for the update.
Old 09-11-2007, 07:41 PM
citizen@large's Avatar
citizen@large citizen@large is offline
CPS!!! I knew it....
for those searching- Crankshaft Position Sensor
