Old 11-22-2002, 02:57 AM
civicracer_1990's Avatar
civicracer_1990 civicracer_1990 is offline
Unhappy Help!!no V-tec!!!
ok..so I did the mini-me swap.....sohc v-tec head on non-v-tec block....my v-tec worked when I first tried it but now it don't work at all......the solenoid clicks but I don't notice a difference....could it be cuz I'm low on oil hence lower oil pressure?? ignition timing??? help me please....oh and AMI you told me not to do it but I'm a stubborn s.o.b plus I like toying around with stuff...can someone help a fellow 4gfreaK??????? PLEASE!!
my dx might lose to an si now :help:
"Faster and Faster until the thrill of speed overcomes the fear of death" Dr. Hunter S. Thompson
Old 11-22-2002, 03:08 AM
Fishcat37's Avatar
Fishcat37 Fishcat37 is offline
Send a message via AIM to Fishcat37
Are you throwing any codes? sometimes a bunch of trouble codes can lead to VTEC not engaging. Low oil pressure (due to low oil) can also cause VTEC to not engage. if you haven't messed around w/ your connections to the VTEC solenoid or oil pressure switch, then it probably wouldn't be a bad connection. Also, if your engine isn't warmed up completely, the ECU will not allow VTEC to engage and a lower revlimiter will be enforced. What ECU are you running, by the way? stock PM6 w/ an rpm activated swith for the VTEC? got a lot of questions.....time to go to bed. hope that started the foundation for this thread, at least
PS- some people might flame you, or rudely correct you that you misspelled VTEC. im not one of those people, but im just tryin to prevent that from happening. just drop the hyphen and you'll be all good
FLINT BLACK 1990 CRX SI
Appearance Mods:
-JDM EF8 CR-X SiR Spoiler
-94/95 Integra GS-R rims
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-Skunk2 Intake Manifold
-DC Sports 4-2-1 Header
-MSD SCI-L ignition
-EXEDY Racing Clutch
Interior Mod
-'95 Integra GS-R Gauge Cluster
Former Motors - RIP:
-JDM B16A #1- Blew up due to over-revving
-JDM B16A #2 - Hydrolocked
Former Cars
'89 CRX Si - "The Bumblebee"
'94 Integra GS-R
'96 Camaro
Old 11-22-2002, 03:19 AM
oops.....I'm running the pm6 ecu and an rpm activated switch....my ******** Valve Timing Electronically Controlled***** like kicked in and out.....its weird its completely warmed up ..:help:...no codes on the pm6....could it be my ignition timing too?? oil pressure????
:help:
I LOVE YOU GUYS!!! i live a town of 300 people in the woods of wisconsin I'm the only import basically my friend moved here from :help:hayward california and he bought a 4g hatch too....we're trying to represent (n.a civic commercial) but I need all your help....thanks..
:help:
SORRY FOR SPELLING IT WRONG I'M NOT A MORON I SWEAR...ATLEAST I HOPE I'M NOT.....HELP ME!!!!:help:
Old 11-22-2002, 12:49 PM
91civicDXdude's Avatar
if you're using pm6 ECU with rpm activated switch, it dont matter if your car is warmed up or not. VTEC will engage when the rpm activated switch engages it. the p28 ECU determines if the engine is warmed up enough to use VTEC. The only thing that could cause VTEC not to engage if your circuitry is all correct would be low oil pressure.
Before i did my complete d16z6 swap, i tried to put the VTEC head on my d15b2 block. The oil rings were shot in the d15b2 block so the oil pressure was really low and so VTEC wouldn't activate at all.
Old 11-22-2002, 12:56 PM
hm...I'll check my oil and if its low cool...if its not....I'll get the 95si oil pump....it fits and does raise your oil pressure....I think....I hate being vtec less....how does being low on oil effect the pressure....I would think as long as the oil pump is pumping it would be fine.....no??? I'm just taking a guess
Old 11-22-2002, 01:27 PM
ok...well...I went outside...in the beautiful 32degrees and checked my solenoid..its not clicking...but I hear a sound inside the head but the solenoid is quiet.....is that bad..I'm on my way to get another solenoid....vtec runs right off of 12volt right???? someone told me 9volt....civic parts free for me....love my local junkyard
