Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 09-09-2007, 07:14 PM
gelcol gelcol is offline
Dodge 2001 pickup truck coding
p1762 ?
thanks!
Old 09-09-2007, 08:00 PM
wayneo69 wayneo69 is offline
Re: Dodge 2001 pickup truck coding
governor pressure sensor offset improper voltage (in the trans) need to drop the pan to replace it and check the wiring from seloniod to main connecter known to rub through i usually re place the transducer at the same time sensor is expencive 80 or more and transducer around40 might as well replace trans filter while your at it because you have to remove it anyway to do the job sensors are right side front of valvebody and the wires run from there around the front to the left side of trans to main connecter
