Old 09-09-2007, 03:41 PM
quick89 quick89 is offline
Need help with 89 wiring
I recently purchased a 89 cherokee for $300.00, with no radio, im trying to install one but i cant determine which colors of wires go to what. EX: power, antenna, speakers, etc.
Old 09-11-2007, 08:21 AM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Re: Need help with 89 wiring
Sorry...looked for wiring but could not find one for your year.
However...a radio is just:
  • a battery fed hot for the memory
  • and ignition fed hot for the radio/amp
  • some kind of ground
  • speaker wiring ...left and right out
The antenna is a big fat shielded lead. No power antennas on most XJs.
Old 09-11-2007, 04:21 PM
Thanks, but i know that, i just need to know what clored wires do what?
Old 09-12-2007, 08:41 AM
AlohaBra's Avatar
Sorry..no diagrams that old here.
If it were mine I would use a voltmeter to identify the hot leads. The ground is usually black. You can use the ohmeter to test for ground. Sometimes the radio bracket is the ground.
For speakers, take the door panels off and look. You might need new speakers anyway if the Jeep is that old.
There might be a diagram here:
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old 09-18-2007, 08:52 PM
Thanks for the info, I'll see what I can do.
Old 09-22-2007, 05:50 AM
Stick89's Avatar
Stick89 Stick89 is offline
Send a message via Yahoo to Stick89
Try this....you have to register....but there is no $$$ involved...diagrams IIRC cant be printed from the site...
http://www.the12volt.com/Default.asp?
WOULDN'T IT BE NICE..IF WHEN WE SCREWED UP..TO JUST HIT..CLT...ALT..AND START ALL OVER AGAIN
