Old 09-09-2007, 01:28 PM
handieeeeee handieeeeee is offline
94 Pontiac Grand Prix SE 3.1 VSS
My car won't shift past second and the spedometer doesn't work. These are the symptoms of a bad VSS. I replaced the VSS and it ran fine for a day and now it is doing it again???? I am lost.
00' Olds Alero
98' Dodge Intrepid ES
94' Pontiac Grand Prix SE
Old 09-09-2007, 02:55 PM
taillight taillight is offline
Re: 94 Pontiac Grand Prix SE 3.1 VSS
Look for loose wiring.
Old 09-10-2007, 05:09 PM
I checked the wires at the module and everything looks good. Could this be the vacuum modulator? What other wires should I check?
00' Olds Alero
Old 09-10-2007, 07:20 PM
Just in case this has something to do with it I also have to start my car twice to get it to stay running and it is very sluggish on acceleration.
00' Olds Alero
Old 09-10-2007, 08:33 PM
Could my ECM be bad?? How do I test the VSS module or the ECM?
00' Olds Alero
Old 09-11-2007, 08:31 AM
First pull any trouble codes. Fix those.
Old 09-11-2007, 09:38 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
The speedo signal is sent from the VSS to the ECM, then to the cluster. If there is a problem with the ECM, it would cause what you descibe.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
