Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 09-20-2001, 06:47 PM
BERTA BERTA is offline
Send a message via AIM to BERTA
Thumbs down Timing Belt 323i
REPLACE TIMING BELT 1984 323I PUT IT TOGETHER BUT WON'T START. IT BACK FIRES. CHECK COMPRESSION. COMPRESSION ON 3 CYLINDRES.ANY SUGGESTIONS?
Old 10-02-2001, 08:48 PM
Groo Groo is offline
Most likely when U took off the timing belt the timing gears have rotated (possibly only one).
-=- GROO -=-
Old 10-03-2001, 10:05 AM
possible. is there a workshop manual for euro? i beleive there is but i can't find it.
Old 04-22-2004, 06:09 PM
scotthuss scotthuss is offline
Re: Timing Belt 323i
Make sure you have the cam and crank timed perfectly with the marks and the distributor as close as possible. The distributor is easy to adjust the few degrees necessary to get it to run. Did the belt break or is this just the preventive maintenance change?
