Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 09-09-2007, 03:12 AM
scott83 scott83 is offline
brakes problem
87 lebaron 2.5.. brake pedal goes to the floor.. when you push the pedal you can hear like a air leak.. just happened all at once.. think it might be the booster.. does have a little bit of stop to it when the brake pedal is touching the floor
Old 09-09-2007, 09:51 AM
taillight taillight is offline
Re: brakes problem
Sounds like either you have a leak(check all four wheels) or the master brake cylinder went bad.
Old 10-16-2007, 04:48 AM
Re: brakes problem
it has no leak..
Old 11-01-2007, 09:10 PM
ricebike ricebike is offline
Re: brakes problem
Originally Posted by scott83
it has no leak..
i second your thought about being the booster, or the one-way check valve, or mebbe the hoses to the booster...
what's the update?opcorn:
Old 11-01-2007, 11:57 PM
Re: brakes problem
it has a little bit of brakes but not enought that you can drive it. what is the check valve that you are talking about
Old 11-02-2007, 08:17 AM
Re: brakes problem
the plastic thingie connected to the booster... one way check valve that can be tested easily...
there's another quick test to see if the brake's booster is "airtight" but gotta run.
local library should have a car repair manual on this vehicle by now...
wait, www.autozone.com has a free repair guide online for your vehicle...
GL!
Old 11-02-2007, 05:31 PM
KManiac's Avatar
KManiac KManiac is offline
Re: brakes problem
If your pedal is going to the floor, the problem is NOT to power booster. The problem is either bad internal seals within the master cylinder or an external leak in the hydraulic lines or wheel cylinders. Naturally, anytime the brake pedal travels as much as your's does, the vacuum system in the booster will make some type of vacuum noise, when the engine is running. Also, check your brake fluid level in the master and top off, especially if it is low.
"This car may be old, but it will still climb Kirker Pass at 110!"
1962 Chrysler 300 2-door hardtop/1964 Chrysler 300-K convertible/1964 Chrysler Newport 4-door sedan/1964 Chrysler 300-K hardtop with Firepower 390/2x1964 Chrysler 300-K hardtop/1964 Chrysler 300 convertible/1964 Chrysler "Silver 300-K" with factory 4-speed/1964 Chrysler New Yorker Salon/1980 Dodge D-50 Sport/1986 Lincoln Continental/1989 Honda Accord DX/1989 Lincoln Mark VII BB/1991 Dodge Shadow ES convertible
Old 11-02-2007, 11:06 PM
Re: brakes problem
yes we checked it again today and it does have a small leak.. back by the back passenger tire where the metal line screws into the rubber line it is leaking right there, but it is leaking on the meatal line side of the connector, might have a pin hole somewhere by the flange
Old 11-03-2007, 07:25 PM
madmanmapper's Avatar
madmanmapper madmanmapper is offline
Re: brakes problem
Rusted out metal line then? Replace the whole line.
