Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-08-2007, 10:35 PM
newguy2007 newguy2007 is offline
Another stupid question about 96 rs
Just yesterday this started. Everytime i hit my fucking brakes there is a high pitched screech and then i let off and it still screeches for a few seconds. I figured i needed new brake pads and shit but i just put brand new ones on like 4-5 months ago. Shouldd they need changed that soon?
Old 09-08-2007, 10:47 PM
eclipse787 eclipse787 is offline
Re: Another stupid question about 96 rs
i'm thinking you need to rebuild your master cylinder. When you apply your brakes and then let off the brake pedal, the brakes are still applying pressure to the disk, making them wear out ALOT faster. Try testing your master cylinder.
Old 09-08-2007, 10:48 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
I doubt its the master cylinder, if that was bad the brakes probably wouldn't work well at all. The MC uses vac pressure to pull the brakes back in so I guess you might could have a problem there.
No they shouldn't need to be changed again. Did you have the rotors turned or put new rotors on? Did you put the brake grease on the backs of the pads?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-09-2007, 12:42 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Did you even pop a wheel of and check the pads? Seriously dude, it would have taken you 10 minutes.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 09-09-2007, 04:30 AM
MazdaX's Avatar
MazdaX MazdaX is offline
That noise is usually called a brake pad wear indicator meaning it's about that time for new ones. If you put on new ones less than a half a year ago , you are braking way too hard way to much and most likely have cheap-o brakes pads with those conditions = instant wear.
2004 Mazda 6i
1997 Tahoe
