Old 09-08-2007, 10:25 PM
eclipse787 eclipse787 is offline
car parts
I need to know some websites that have lots of parts with good prices for my eclipse (420a). For the most part i'm looking for a crank, rods and pistons. Eventually everything else...
Old 09-08-2007, 10:36 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: car parts
I would just go on ebay and get the pistons and rods. You dont need a new crank, the stock one is fine. You can get bearings anywhere. You could try howellautomotive.com
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-08-2007, 10:42 PM
Re: car parts
Well see the thing is, i got the car for 700 bucks because it knocked. Number 4 rod had about 1/8 inch clearance between the rod and crank. The rod and crank is shot. So i decided i'm just going to rebuild the entire bottom end. But i'll try the ebay thing and the other website you gave me
Old 09-09-2007, 12:10 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: car parts
I would hit up SBR, they should have a everything you need, but they are on the expensive side for some things so shop around. Are you really going to need a bullet proof botto end? If it were me, I would just buy a junk yard bottom end and use the crank and rod from that.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 09-09-2007, 10:22 AM
MexRocket's Avatar
MexRocket MexRocket is offline
Re: car parts
I agree with Th0r take it to any machine shop after finding a none damaged block... they do wonders with honing and cleaning
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 09-09-2007, 03:00 PM
Re: car parts
well eventually i'm going to put turbo nitrous and everything else you can imagine into this motor. i want rods that will hold up at 7 to 8 thousand rpm's. stock rods won't do it. but i'll sbr
