Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-08-2007, 10:12 PM
newguy2007 newguy2007 is offline
Is my powersteering out??
Whenever i turn the wheel too sharp to the left or right there is a loud screech from my car. Is it my powersteering pump? How much do they run and how hard are they to put in?
Old 09-09-2007, 12:02 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Is my powersteering out??
Please use the subforums.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 09-09-2007, 12:47 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
PS pumps are super easy to install. Just had mine out today playing with it. It may be something else though. I had a leak in mine and once it got low on fluid it would screech also. Check your PS fluid levels. If low, fill, and see if that works. The dip stick thing on the PS resivoir isn't always the best. Check, even if full, add a little to it and see if the level changes.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-09-2007, 11:50 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Its probably just your belts, mine squeel a bit when I max the steering out. Try tightening the belt and see if that helps any.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-09-2007, 06:55 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
If you turn in one direction all the way until the wheel stops turning and hold it there, you will hear a sound come from the pump because your putting a lot of strain on it. You would know if you had no powersteering, you would barely be able to turn the wheel at all.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 09-09-2007, 09:47 PM
rickyrickster25's Avatar
rickyrickster25 rickyrickster25 is offline
mine also makes noise when i max it out, but it doesnt sound as serious as you are saying yours is.....
97' Eclipse RS 5 Speed 420A
Under The Hood:
Bomz UDP, Custom CAI, NGK Plugs, Mopar Wires
Interior:
Blue Glow Dash Guages & HVAC Controls, Neon Accents, Custom Dash Work\Paint, Alpine Type-R/JL Audio System, Custom Trunk Layout
*GOAL* - Prove Him Wrong
Originally Posted by UnderEstimate Me
I doubt bolt-ons will get you to 160hp on the 420a. Unless you have some dyno sheets Im calling bs.
Old 09-09-2007, 10:36 PM
david-b's Avatar
Dave is THAT guy
Driving without power steering is fun. Haven't had mine working in months. Best on the expressway seriously. Parking sucks, but it's worth it. You'll know when it's gone or going.
When mine was going, I'd be turning, and it would cut out half way through the turn. You know how many trees I almost hit because of that? I did hit a curb once.
75 Monte Carlo
Old 09-09-2007, 10:51 PM
Holset powered 420a
I threw the belt off one time and had to drive home with no ps. It made the steering feel more solid but sucked at low speeds.
98 Eclipse GS Turbo
2001 BMW 325i - DD
