Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 09-08-2007, 09:23 PM
emarkay's Avatar
emarkay emarkay is offline
1984 Caprice, Bone Stock, want a "Posi" rear...
What can be put in the factory housing - a rebuilt Positractionn, a new Torsen, or what? Don't need the ratio changed, nor looking for a "dragster locker", I just want the wet weather/ice advantage of the limited slip rear.
What's the most cost effective way to do this?
What interchange rears can fit - if I get a "lo-mile Junkyard" rear?
Thanks!
1984 Chevrolet Caprice Classic
1998 Oldsmobile Aurora
Old 09-08-2007, 10:07 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 1984 Caprice, Bone Stock, want a "Posi" rear...
Your car most likely has a 7.5" rear axle in it. Rear axle assemblies from GM B-body cars between 1977 and 1996 will directly bolt in if they're the same size as yours (7.5" or 8.5"). You can go with an 8.5" axle, but you're looking at shortening the driveshaft 1" (or obtaining a fitting driveshaft from the donor vehicle, provided it has the same transmission as yours) if you go from 7.5" to 8.5". You're also looking at different wheels for the back due to bolt pattern size (unless yours is a wagon, it's likely to be 5-on-4.75" and the 8.5" is going to be 5-on-5". Wagons are 5-on-5").
You can get posi carriers for either size axle.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
