Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 09-08-2007, 07:50 PM
Georgiaboy83 Georgiaboy83 is offline
89 dakota wont crank
i have a 89 dakota it cut out on me why driving, pulled off tried to re-crank it wont fire nothing from the the switch, have head lights but the volt meter reads nothing and ac still works.
Old 09-09-2007, 09:58 AM
taillight taillight is offline
Re: 89 dakota wont crank
Look for a main fuse or fusable wire.
Old 09-11-2007, 04:06 AM
i have checked all of the fuses and they are all good, but i fuseable link blew and now i am trying to run down the short but it is just taking time.
Old 09-11-2007, 08:10 AM
Look for missing insulation.
Old 09-11-2007, 11:33 PM
Andydg Andydg is offline
When that happens to me I put'er in first then back up to park a few times and she fires right back up...doesn't happen very often though.
Old 09-25-2007, 10:43 PM
zulu38 zulu38 is offline
You may have a park/neutral switch, located on the transmission housing, if automatic, gone bad.
My 1989 is sitting in the driveway now. The starter will not work.
It could be the shifter linkage needs adjustment also.
Good Luck!
Robert
Old 09-26-2007, 09:42 PM
I haven't had time to check out my starting problem on my "89 Dakota, 3.9, Automatic Transmission, 4x4.
Symptoms: 1. Head lights are strong, so it isn't the battery.
2. When moving the shift lever thru the gears, there is no drag.
3. Would a bad Neutral switch cause this, or do
you think there is a linkage problem?
Old 09-27-2007, 01:57 AM
i just finally took it to my local dealership. it cost me over 400 just for a wiring harness to be replaced.
