Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 09-08-2007, 07:39 PM
emarkay's Avatar
emarkay emarkay is offline
1984 305, AIR pump Q's
Let's say, for testing purposes only, I l removed the AIR pump "fan belt".
OK, no more air at warmup in the exhaust, and maybe 1/2 hp gain.
Next, I plug all vacuum hoses and remove the TVSS switch, and put my mechanical temperature gauge sender there. (Putting it in the thermostat housing, where it is, is sort of pointless unless I am towing a trailer in Phoenix in August up a steep hill...)
Would I need to remove the AIR pipes and plug the holes on the manifold, or is this system "fail/safe" in that possible backfires and other things are prevented from "backflowing" if the AIR pump no longer spins?
Thank you!
1984 Chevrolet Caprice Classic
1998 Oldsmobile Aurora
Old 09-08-2007, 08:06 PM
mike561 mike561 is offline
Re: 1984 305, ARI pump Q's
This was done on mine when i bought it, they removed the air pump, capped the vaccum openings on the carb, and removed the air injection pipes too. i got brass caps to plug the manifold where the pipes used to be because they just cut the pipes but left then in. its all just emmissions, i would have left all of it on but since we dont have testing here in FL everone removes most of their emmissions stuff.
2006 Chevy Cobalt LS
Old 09-08-2007, 09:01 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Hmm <scratches chin> ... 38-year Phoenix native here. I don't recall seeing any steep hills of any consequence anywhere within 30 miles of here!
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 09-08-2007, 09:15 PM
emarkay's Avatar
OK I was being facetious, but having a relative in Tempe, and having done the Route 66 trip, I remember a Jerome , the 2 mile-almost-straight-up-trip to Sandia Peak, and of course three's Oatman for a hill-haul.
Thanks for the input - I just want to free that sender port, and figure that even if IN ever does smog chex (one reason I moved from PA) , they won't be doing it at cold idle, and I can always put the belt back on and "mock-up' the system for looks...
