help please
I have a JGC with a 5.2 V8 (1996) i have general questions that i could not find answers for when i did a search here.
1. other than the motor mounts, are there any other bolts to remove when pulling the motor out, and what is the best way to access the other bolts, as i dont see if there are bolts, attaching it to the tranny. Should i pull the starter and undo the bolts in the flywheel assembly? 2. Other than using a spanner wrench is there any way to pull off my engine fan from the water pump? 3. Does anyone know the size of the crankshaft pulley bolt, the motor is seized and I am trying to turn it. Should i fill the cylinders right up with oil, (RIGHT TO THE TOP, AND LET IT SIT FOR A WHILE). any help is appreciated. thanks! |
Re: help please
As far as the cooling fan I usually use the proper size combination wrench 1 3/8 or whatever it is and put it on the hex with the wrench standing straight up and hold a little pressure on it with my left hand and strike the wrench sharply with a good size hammer in my right hand and if it doesn't loosen on the first blow give it another. You must hold a little tension with your left though or it won't work. If the engine is seized you may as well kiss it good bye as it either seized from lack of oil or water and more than likely the pistons and rings were ruined. Depending on what happened the block probably isn't even salvagable. |
