Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 09-08-2007, 03:03 PM
BonnieGirl BonnieGirl is offline
Signal Lights
This is my first time on this site. I hope I'm doing this right. I have a 1995 Bonneville SSEi. My signal lights want work. We have replaced the fuse but as soon as when put the fuse in and turn the car on the fuse blows. My hazard lights work fine. Can someone give me some suggestions on what to do next.
Thank you
BonnieGirl
Old 09-09-2007, 10:29 AM
taillight taillight is offline
Re: Signal Lights
Look for a short. A wire pinched or broken.
Old 09-09-2007, 11:00 AM
Smile Re: Signal Lights
Where do we start with the steering wheel column? How do you take the steering column apart?
Real new to this. My husband and I are trying to do this ourselves because I know the dealer is going to charge and arm and leg just for labor alone. My husband is an eletronic tech so if he can get some info into what direction to do we can do it from there.
Thank you
BonnieGirl
Old 09-09-2007, 11:38 AM
Re: Signal Lights
It would be easer if you had a wiring diagram of the car. You could try to find one on the net or a Haynes manual. Start at the fuse or at the tail light and try to follow the wire inch by inch looking for a place where the insulation is off. Because the hazards work the problem is between the fuse and the hazard switch. There is also a brake light switch but if that works it is before there. From the fuse it goes under the dash and then to the steering column. You have 4-5 feet of wire to look at.
Old 09-09-2007, 11:42 AM
jdq jdq is offline
Re: Signal Lights
Dumb question but did you pull the bulbs , I had a issue where the bulbs were all rusted and did the sams sort of thing.
2000 bonn ssei 155000 klm
1997 dodge caravan 92000 klm
Old 09-09-2007, 11:52 PM
Re: Signal Lights
Thank you for your help. Look like we have our work cut out for us. This is my second bonneville and I love them. Will let you know what we found out.
BonnieGirl
1995 Bonneville ssei
Old 11-17-2007, 08:06 PM
fuelmaxman fuelmaxman is offline
Re: Signal Lights
ok, i think that u have 1 of two problems, one being very simple, and the other really not so bad. first, under the column remove the four 10mm bolts that hold the cover on by your knees, and check the directioanl flasher. it may be shorted out or "burnt" up so that the signal is shorted out as well. it's a round silver thing with two prongs. can't miss it. next is your directional switch in the column under the cancelling cam and air bag. cunsult a local mechanic. thanks for listening folks. over and out
