Go Back   Automotive Forums Car Chat > Buick > Riviera
Old 09-08-2007, 07:42 AM
Rolanduo Rolanduo is offline
95 Riviera AC problems
Did a top end rebuild on my 95 SC Riviera. AC worked great before the rebuild but it did sit for 6 months. The R134 is at pressure and everything looks/seems good. The clutch doesn't seem to be engaging on the compressor. I have not been able to check for a signal through the plug yet. What do you think is wrong, and what signal should I get through the plug if I test it. Plz help.
Old 09-08-2007, 09:55 AM
taillight taillight is offline
Re: 95 Riviera AC problems
With the A/C on you should have 12 volts at the compressor plug.
Old 09-08-2007, 10:49 PM
Checked the AC clutch plug voltage and have no reading while the car is on and AC is turned on in the car. Checked the fuses/relays, everything looks good. Where should I look next, or is this a problem I should let a mechanic figure out.
Old 09-09-2007, 09:06 AM
If you are low on R134A the compressor will not work. Unplug the A/C pressure switch and put a jumper wire across the 2 terminals in the plug(not the sender). The compressor should run.
Old 09-16-2007, 08:47 AM
driviera driviera is offline
I am having the same problem with my a/c i was told to try replacing the relay box under the drier. i dont really have the time to do it right now but if i do get the time i will let you know if that works.
Old 09-16-2007, 09:47 AM
2001jettavr6 2001jettavr6 is offline
Should be a sensor on tank that you put in your r134a (too early to think of the name) that engages the compressor clutch with enough pressure if its faulty your ac will not blow any cold air.
