Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-08-2007, 12:45 AM
eclipse787 eclipse787 is offline
turbo- piston compression realation 420a
ok so now i was reading som forrums and some pple were saying that its better to have lower compression when having a high pressure turbo setup. is this true? because i was going to to a turbo with 10.5 to 1 compression pistons and some type of nitrous setup? this a bad idea?
Old 09-08-2007, 12:48 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: turbo- piston compression realation 420a
For future reference, typing like you have an education of a 2nd grader will get you fewer responses...and the people who would most definately be able to answer you question will not even bother.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 09-08-2007, 12:57 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
If your planning on boosting it go with 8:8:1. The lower compression ratio will allow more room for tuning errors. You could get away with higher compression if you plan on running a little bit of nitrous. But your tuning will have to be more precise if you run a big shot.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-08-2007, 01:07 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
High compression, turbo, and nitrous = very bad idea.
I would keep it between 8.5:1 and 9:1 for sure, and I wouldnt necessarily recommend 9:1 but its the very highest I would go (unless you were on E85).
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 09-08-2007, 11:20 PM
alright thanks guys. i think i'm going to go with 8.8:1 wiseco pistons. after i get the bottom end of the motor put back together i'll wrk on getting a turbo. whats the highest boost pressure i can run if i get the 800 hp eagle i beam connecting rods and a stock 500 hp crank?
Old 09-08-2007, 11:25 PM
Holset powered 420a
As much as your fuel can supply. Most people run around 18ish daily but race on around 25psi or so. You better have a good fuel management system in mind and something to retard your timing with that much boost.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-09-2007, 01:34 AM
Thor06's Avatar
Jizzed In My Pants
Easy there Mr. Spilner, step back from the Import Tuner and take a deep breath. Do you really think you'll ever hit 800hp? If so, how are you going to get it to hook? If not, then why 800 hp rods? What fuel management are you going to run? This is not going to be easy or cheap, to take any sort of advantage of 800 hp rods you are looking at ATLEAST like 10 grand. To be honest, I think you're in a bit over your head at the moment.
One thing you should know is that airflow is power, boost pressure (psi) is heat. Yes, there is a correlation, but a t25 on a given boost pressure X will flow a VASTLY different amount of air than a Evo III 16g, a FP Green, and a GT 35R will at that same boost pressure X. As stated above, the fuel system will be one big limitation. Before you can even start your boost fed wet dreams you are going to need some sort of tuning device and most likely new injectors and a pump. Another big one is your intercooling. Too much pressure and shitty intercooling will result in lots of knock which will result in your shiney new motor taking a huge shit right in your lap.
Before you sink your teeth into something really crazy, I would do a LOT of reading if I were you. Theres a few great articles here in the tech article section as well as at DSMtuners.com. And of course, we'll be here every step of the way.
Old 09-09-2007, 11:14 AM
Holset powered 420a
Check out 2gnt.com A lot of people over there have boosted 420a and there is so much info on there. Just search and you will find everything you need.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-09-2007, 04:12 PM
i'm shooting for 400 hp. i just want the 800hp rods because when doing high rev's (wanting to go 7-8 thousand) usually the rods are the first to go. after i do the bottom end i was planning 44 lbs injectors, high rate fuel pump, fuel manegment(http://www.ci-motorsports.net/store/...?productid=525) and a boost controler (http://www.ci-motorsports.net/store/...?productid=527) whats your guy's opions on this setup?
Old 09-09-2007, 04:33 PM
Thor06's Avatar
Jizzed In My Pants
In going for 400 hp, I doubt you would break an aftermarket rod. Just get the standard Eagle ones. I know a guy thats done a lot of fucking around with Haltech and after that I wouldnt recommend it. I would run AEM EMS if I were you. Realize though, that neither of those two management systems are exactly plug-and-play. A great deal of knowledge is needed to tune with them properly.
Other than that, have you started looking at anything else? You're going to need intercooling, exhaust, a decent turbo, intake manifold, cams, a built tranny, a decent clutch, drag slicks, etc.
Also, that boost controller is rediculous, I would never drop $500 for something like that when a MBC would do the job just as well for literally 10% of the price.
Old 09-09-2007, 04:48 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
I've heard bad things about the stand alone. Use MegaSquirt. That will probably be the best way for 400hp for our cars. It's a pretty easy setup and can be tuned on a laptop. Either that, use the AEM EMS. Costly though.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-09-2007, 05:31 PM
Holset powered 420a
Go with megasquirt, that will give you fuel control and ignition control.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-09-2007, 11:26 PM
well found a megasquirt for 795 ( anybody find one cheaper?) but looks like an awsome system. i'm in the process of getting a manual tranny, but what need sot be done to it so it can hold the power? and yes, i plan on upgradign the cams, lifters, rockers, valves, springs, injectors, ci turbo, arp head studs, fidanza axle and a bunch of other little stuff. if anybody has some recomendations, feel free to post!
Old 09-09-2007, 11:48 PM
Holset powered 420a
I beleive you can get it cheaper than that. You just have to search around.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-10-2007, 01:08 AM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
gathering from every one of your posts, either you have to much money to spend, to much time, a little of both, or none at all and your just asking these questions to act "cool" first off, an auto-to-5spd swap isnt exactly a walk in the park... you should be focusing your questions regarding that project before you go off talking about a 400 hp 420A RS... theirs alot of work that needs to be done before you even get to 200 hp... then again, why do all the work if your asking about buying a GSX? Just take it one step at a time man, trust me! it'll work out better for you, as well as all of us... start small... maintain, build up, race, blow up, rebuild, race, blow up, rebuild, race, blow up, etc. (in that order!) but you cant "build up" with out maintaining, you cant (really) race with out building up... see? 1 step at a time bud!
