| Cavalier Problem Diagnosis Got a problem you can't fix? We can help. |
96 Cavi 2.2 Crankshaft Sensor
My buddies car is a 96 2.2, 5 speed, and the code I pulled is the Crankshaft Sensor. Where is it on the motor, my Chiltons manual isnt saying, and how abouts do you replace it. THanks
Re: 96 Cavi 2.2 Crankshaft Sensor
haynes manual is pretty useless to, it says its "mounted to either the front side or the back side of the engine block, depending on engine type"
as far as the process goes it just says to disconnect the electrical connector from the sensor, then remove the bolt from the crankshaft sensor and remove the sensor
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM, 1981 Fairmont 6cyl 3 speed 1978 Ford Ranchero GT 302 with a few goodies |
But where is the sensor and what does it look like?
Directly from my Haynes manual: On 1995 through 1999 engines, look for the CKP sensor directly below the ignition coil assembly, which is also mounted on the backside of the block. From the picture it looks like the only sensor held in by a bolt. Should have a purple and yellow wire running to it. HTH
2010 Mazda CX-7 2.5L 12000 miles 2003 Chevy S10 Extreme 4.3L 57000 miles 1995 Buick Lesabre Custom 86000 miles RIP 2002 Pontiac Sunfire SE 130000 miles RIP 1997 Pontiac Bonneville SE 91106 miles Totaled by attempt to steal the car!! R.I.P. 1978 Ford Fairmont 83000 miles
Is the ignition coil all the spark plug wires go into?
Yes. Before you go and replace the sensor, that codes does not mean that the crank sensor is definitely bad. For some reason, the computer is not seeing what it expects from the crank sensor, hence the code. What you need to do is make sure that all electrical connections from the sensor to the computer are good, and that there is voltage at the wires when the ignition is on. A bad electrical connection can cause the same problem as a bad crank sensor.
Haynes manual #38016, page 6-8, section 4: Crankshaft Position (CKP) sensor - replacement
hmm, mine is #38016 as well but its certainly not the same book, mine says its for 95-2001 models though so i guess that changes a few things
Alright the exact code got from the scanner is P0335, something about Crankshaft Position Sensor A Malfunction I presume, if someone wants to double check? I looked today and couldnt find anything with purple and yellow wires.:P
