Old 11-21-2002, 02:05 PM
Redline_civic91 Redline_civic91 is offline
Send a message via Yahoo to Redline_civic91
grinding gear...............
my third gear has been grinding its not that bad, but its there. any fluid out there that can change that. or would i have to take it back to my mechanic so he can fix the synchros.(im trying to avoid that though). im gonna try that redline mtl tranny fluid. any suggestions??
91 civic b20/vtec=sold
95 acura integra=sold
02 chevy silverado=totalled
95 honda accord=please i hope nothing happens to this!
Old 11-21-2002, 02:13 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
Tranny
once it's to the point to where it's grinding theres nothing that can help it but a tear down and re-build.
Old 11-21-2002, 02:49 PM
i just talked to a pretty good source and they said thats a sign of the tranny going out. 3rd is usually the first gear that goes out. and they also told me honda has the only tranny that takes engine oil. the same oil you use on your engine is used on the tranny. didnt know that.
Old 11-21-2002, 03:45 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
My third grinds when I am trying to shift fast, but other than that its pretty good, sometimes I double clutch into it.
Keep tryin to send me the pics man.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 11-22-2002, 10:09 AM
kaytec4door kaytec4door is offline
so your tranny is grinding into third, well my friend fishcat37 i did his b16a swap into is 89 rex and his had bad grinding problems, we tried redline and that stuff made it worse so we heard from a friend that GM SYNCHRO MESH was good so we said what the hell, when we changed it it still ground a little bit but holly sh## it was like four times better than before, so i would highly recomend that stuff
:smoker2:kaytec4door:smoker2:
mods done: AEM cold air intake,
ractive racing cat,
ractive axel back exhaust,
NGK plugs,
nuespeed cross-drilled rotors,
EBC the green stuff pads,
projecter headlights,
clear corners,
carbon fiber tails,
Z3 fenders,
adjustable coilovers,
Konig flatline rims with dunlop fm901 (17*7),
full complete sound system with two 10'' subs,
kenwood 600w amp,
punch cap,
pionner speakers all the way around,
full custom interior paint job,
reverse indiglo guages,
aluminum gauge bezel,
d16a6 head swap polished,
4-2-1 ceramic coated header,
:finger4: proud member of team kay tec:finger4:
Old 11-22-2002, 11:05 AM
where can i pick some of that up??? im gonna use redline oil on my engine for now on and i've been told you use engine oil on your honda tranny too. so i was gonna dump some of that in there.
Old 11-25-2002, 09:43 AM
you can get GM sychro mesh at a parts store i think but the most sure place to get it is at a gm dealer. that is where i got it.
ractive racing cat,
NGK plugs,
clear corners,
carbon fiber tails,
Z3 fenders,
kenwood 600w amp,
punch cap,
