Go Back   Automotive Forums Car Chat > Ford > Tempo | Topaz
Old 09-07-2007, 09:55 AM
benoitd benoitd is offline
Thumbs down Wheel Bearing
Can anyone help me with changing the bearing on my 91 tempo gl? Its a press in on the driver side.
Old 09-08-2007, 04:11 PM
rhandwor rhandwor is offline
Re: Wheel Bearing
I would get a haynes manual and pull the unit. I don't know how much you can do. Various auto parts stores loan tools. Find a parts store who will press the old bearing out and press the new one in for a fee. Ask any friend who has done a job like this to help you. I don't remember if the Tempo has a cam on the strut bolt if it does use a punch and make a mark on both the cam and strut or your wheel will lean in or out 1 inch. You have to pull the CV joint and remove the rotor. With air tools you should have it off in a 1/2 hour. Maybe all day if you don't know what you are doing.
Old 09-08-2007, 08:23 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Re: Wheel Bearing
You need a press. With wheel bearings you need a pretty stout press to get it off. Take the caliper off usually torx or hex bolts, rotor next(just pull off), then tie rod end, then cv lock nut (need a big socket and breaker bar for that one) Then strut bolts like stated above, then ball joint pinch bolt. From what i can remember thats about it. The whole knuckle comes off and you take that to the press. I havent done one on my tempo yet but on a few other cars. Good Luck.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
