Go Back   Automotive Forums Car Chat > Chevrolet > Chevrolet Classics
Old 09-06-2007, 04:26 PM
chevy291 chevy291 is offline
Whats compatible with a 77 454
I need to know wat can take the beating my 1977 454 big block can crank out its for a chevette project I'm building and wat kind of rear end would be best a 9" ford of a 12 bolt chev?..... any advice?
Old 09-06-2007, 06:15 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Whats compatible with a 77 454
OK, tell me. What is it that you want to know about? Transmission? Axles? U-joints? Driveshaft? Bushings?
I hope you're going to subframe the car, or it will meet its demise on the first launch. Vega guys ran into this same problem years ago, and a Vega is larger and heavier than a Chevette.
If you want strength and compatibility (of aftermarket parts), go with a modded 9". They're the strongest, although I fully suspect you will never launch it hard enough to kill a 12". You'd get more smoke and tire burn than traction in that application.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 09-27-2007, 06:19 PM
67chevypickup 67chevypickup is offline
Powerglide
