Old 09-06-2007, 03:51 PM
900FE_79 900FE_79 is offline
Question Question: How to pull off spark plug covers
This might seem like a stupid question but as I tried to pull the plug cover off the front plugs last night I could budge them. I have never seen plug covers like the ones on my Grand Prix and the manual says you need a special tool to pull these off.
Are there any tips on how to pull the covers off, especially the back ones?
Old 09-06-2007, 04:36 PM
inafogg inafogg is offline
Re: Question: How to pull off spark plug covers
What engine, What year??
Old 09-10-2007, 01:47 AM
chevyguy93 chevyguy93 is offline
if your talking about the metal sheath, i used a screw driver and vice grips to pry them off. (note: i had to bend them back into shape afterwards :P)
2003 Grand Prix GT
1993 Cavalier 2.2L
Old 09-10-2007, 05:56 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I have a set of 45 degree bent needlenose that I use.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 09-10-2007, 10:54 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Its not the metel shields thats holding the spark plug boots on. Dont Mutilate them!!!!!!!!!!!!!!!!!!! Clamp a small vice grips to the part of the boot sticking out the back of the shield. Twist back and forth to break the boot free from the spark plug porcelin, and then they should be easy to get off!!!
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 09-10-2007, 01:09 PM
if you are talking about removing the plug wire from spark plug.There is a tool its about $5.Dont grab & swist/pull you'll damage plug wire.Buy the tool its much easier & can be bought at an auto store.
Old 09-10-2007, 10:14 PM
Langning Langning is offline
Just did my #6 spark plug last week (#1 to #5 was replaced last year and I couldn't reach #6). My cheapo spark plug puller was too "big/long" to maneuver on wire #6. This time I resorted to use a slip joint plier (similar to this one <img src="http://www.redboxtools.com/product_images/1048.jpg"> ) to grip on the rubber boot and twist & pull it out. This was with the engine pulled forward with a ratcheted vinyl strap to give my hands extra space. The old wire came out with no damage but I replaced it with new wire anyway.
Save the $5 and invest the money on a new wires.
Old 09-11-2007, 02:11 PM
yea i agree if you need wires but what are you going to do next time replace wires again???
Old 09-11-2007, 04:28 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Regardless of whether you replace the ignition wires or re-use them be sure to use dielectric silicone grease on the insides of the plug boots spark plug side. Removal will be much easier next time around. Also, use anti-seize compound on the spark plug threads and do not over torque. Around 20-25 lb-ft.
Timeslip 08/12/06
AF Community Guidelines
