Ok this might sound a little weird but, my ac was working fine the other day... now i have cold air coming out of the vents on the right side ( 2 vents ) and Warm/Cool air coming out the left side ( 2 vents ) and the center vent ( 1 vent ) Warm/Cold air..... i have the 3 knob ac controls, anyone ever have this happen to them before?? o and the air on the right side is a little harder coming out than the other 3
thanks for any help |
Re: 97 gtp AC problem
anyone??
What is this guys? A restriction in the evaporator? Or is it low on freon? Have it checked for proper high side and low side pressures at a qualified ac service shop
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
It sounds like one or more (most likely one) of the door actuators that control air direction is bad. However, this can be difficult to fix without the proper tools, wiring diagrams, component location reference, and time. If it blows cold out of one side your freon charge is good. It can take a lot of time to take apart the dash. Then again, you made not need to as the bad actuator might be easily accessible. Then again, how do you know this is the bad actuator since there's more than one? Then again, do you have the diagrams to properly test the actuator? See what I mean? If you decide to have a go at it, you can try back for help. Hopefully, someone else might have had the same problem and can assist you. Maybe there's a recall or TSB. |
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
