Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 09-06-2007, 09:45 AM
player11 player11 is offline
Timing Belt--when to replace?
What is the concensus here on the 3.2L? 100k miles? less?
Old 09-06-2007, 11:25 AM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Re: Timing Belt--when to replace?
For the 3.2 it should be done at 100k miles along with the water pump and tensioner. You can go over though, its a non interferance fit engine so if it breaks it shouldnt hurt anything.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 09-06-2007, 12:46 PM
amigo-2k amigo-2k is offline
Isuzu Guy
If you wheel or tow do it before 100k. If not any time after 100k. I'm going to have mine done at 120k.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 09-07-2007, 12:54 AM
trooperbc's Avatar
trooperbc trooperbc is offline
yes...or more...
isuzu recommendations started at 60,000, then 75,000, then 100,000....
what year? has it been done before?
and while it's noninterference, there are other considerations. namely the water pump (which should be done at the same time, btw) can bind or seize causing the belt to get cockeyed and cut up the timing belt covers. not to mention, you don't want the waterpump going out.
//bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Old 09-07-2007, 08:38 AM
Ramblin Fever Ramblin Fever is offline
Yes, the waterpump itself can wreak havoc before the actual timing belt.
Waterpump is behind the timing belt, so make sure you do all 3 items at minimum - timing belt, timbing belt tensioner, and waterpump!
Also agree that if you tow or wheel, or live in a very hot climate and then return to a cold climate, have it done between 85-100k or so. If your truck is basically a city dweller, easy rider, 100-120k should be pretty good.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 09-18-2007, 10:16 PM
Stuffy Stuffy is offline
What about a timing belt and tensioner change at 62k on a 93? Still change 100 to 120 because they missed the water pump?
Old 09-18-2007, 11:39 PM
trooperbc's Avatar
well that is the conundrum, isn't it?
i can only tell you that i did that kind of skip, and when the water pump went it also took out the timing belt covers when the belt was forced partially of its course. so i got to do it all over again.
//bc
Old 09-19-2007, 08:06 AM
2000izusu 2000izusu is offline
isn't there an age limit of 7 years (on timing belt) if you put on very few miles?
2006 liberty 3.7 6speed manual
1999 cherokee classic 4.0L
1991 wrangler yj 2.5L
2001 caravan 3.3 auto
1995&1992&1994 camry 2.2L SOLD
1991 silverado 1500 SOLD
2000 rodeo SOLD
