Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-05-2007, 11:30 PM
eclipse787 eclipse787 is offline
auto to manual parts list
ok so i bought a 95 gs with an automatic for real cheap (700) and planned on swaping from auto to manual, which i'm dedicated to doing. i just need to know what ot buy, other the the tranny and clutch of coarse, to get the project done. money is somewhat of an issue also....
thanks guys
Old 09-05-2007, 11:53 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: auto to manual parts list
It's your lucky day. I did your searching for you.
http://www.ecanfix.com/~mdhamilton/autotomanual.html
It's for a 1g, but the parts list and procedure are similar. This will just give you an idea of what your getting into.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 09-06-2007, 10:47 PM
thanks for the help man, but if any bosy finds anything about the 2g's. please let me know.
Old 09-07-2007, 10:26 AM
caniborrow50cnts's Avatar
caniborrow50cnts caniborrow50cnts is offline
Send a message via AIM to caniborrow50cnts
well, with the 2g's, you have to remember to install the flux capacitor. this will help you channel that power that you need to break the time barrier.
I got a tranny I can sell you real cheap. $20, you would just have to deal with 2nd, 4th, and 5th grinding every shift
If you got a gs, it has the 420a motor, which is a chrysler based motor. The biggest thing you would have to worry about in this swap, is the ecu. the automatic tranny computer would be removed, but this would easily affect how your car idles if you do not reset the main computer under the hood. the only two wires to the tranny would be reverse light and speedometer. Good luck with the swap. you are going to need some patience to work in that tight area. you are going to have to remove some extra parts that in the way to make the process go faster.
72 Beetle - trashed
88 Escort EXP - dumped
92 Talon - sold
97 Eclipse RS - still own
99 Eclipse GST - still tearing up the asphalt
Old 09-07-2007, 10:59 PM
so how do i reset the computer under the hood? and being that i took both the tranny and motor out i'm hoping it will be alot easier.
