Old 11-20-2002, 11:28 PM
b16b bomber b16b bomber is offline
idle problem
Does anyone know why a b-series engine would idle at 1500 all the time....even when it is warmed up
Could it be the throttle position sensor?
what other reasons can there be for such high idle???
thanks for your help
1998 Honda Civic Ex
Mods:
B16B Swap
Spoon 1.6L to 1.8L conversion
Skunk2 type 2 camshafts w/ titanum retainers and springs
Skunk2 Cam Gears
DC Sports JDM 4-1 headers
Hi Flow Catalytic Converter
AEM CAI
Old 11-21-2002, 01:21 AM
strodda strodda is offline
dont know, but just pop the hood and adjust the idle.
Old 11-21-2002, 07:37 AM
higgimonster's Avatar
higgimonster higgimonster is offline
your engine might be running in Limp-Home-Mode (the technical term). it is a sort of safe mode. You would haveto check the codes in your ecu to figure that out. otherwise, you could do what my friend and I did whith his BMW that was idleing around 1.5k: shave down a cork from a wine bottle and put it in the AIC (Automatic Idle control) hose. Worked like a charm.
Promoter of the one line signature.
Old 11-22-2002, 11:10 AM
RoBoDEATH RoBoDEATH is offline
Send a message via AIM to RoBoDEATH Send a message via Yahoo to RoBoDEATH
on your throttle body is a fairly large screw, if it's never been adjusted it probably has a little film on it, tear the film off if it's there and slowly turn the screw while then engine is running and have someone sit in the car and watch the tach, i've heard about 650 is normal
1998 Honda Civic EX--Si Wing--Jackson Racing Supercharger--Enkei RP07 18inch Rims--Yokohama PARADA 215/35ZR/18's--K&N Filter--Hurst ShortShifter--DC Sport Header--Greddy Cat-Back Exhaust--DC Strut Tie Bar--Eibach Springs with Ground Control Coil Overs--Ingalls Rear Camber Kit Arms--Skunk2 Front Camber Kits--Panasonic DF88 CD Player--Two 1Fared Caps--Sony Xplod 800W Amp--SPL Series II 1200W Amp--Solo Baric 15--!!!!!SOLD!!!!!!!
2001 Honda S2000 NFR--HKS Hi-Power Duel Exhaust--NRG Hood Dampers
