Old 09-05-2007, 08:54 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
Need some help
ok, the Civic i bought is in need of some help...i need to know how to remove the whole ignition from the steering column and the door locks
whe i bought the car the ignition was screwed...could start the car with basically anything...and he gave me two keys, which neither fit the door locks...well found a car to buy parts off and i need these 3 things by saturday...so if someone knows how to remove these parts or has a manual and can scan in the pager i'll be grateful
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 09-06-2007, 06:58 PM
BLU CIVIC's Avatar
調整器
Re: Need some help
anyone
The name's Adrian
2011 CR-Z - Stock
Old 09-06-2007, 07:11 PM
Hybrid1990crx's Avatar
Re: Need some help
to get the ignition housing off the car you need to cut slots into the screws since they dont have them on there and use a flathead to turn them out. or you can use a really sharp chissel but I've found cutting slots to work the best.
for the door locks I dont know, ive never done one on a honda.
Old 09-06-2007, 07:36 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Need some help
http://www.crxpower.net/~silverkorn/...hop_Manual.pdf
Page 375-376 (14-3, 14-4) for the door locks.
Page 532-533 (16-30, 16-31) for the ignition (not great pics).
Old 09-06-2007, 07:37 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: Need some help
Get a #1 Phillips screwdriver, or a scratch Awl(something with a sharp point you can hit with a hammer). Hit it a few times on the headless bolt holding the ignition switch in to get you a nice notch to work with. You want to try to make this notch towards the edge of the bolt, it makes it much easier. Once you have your notch, start tapping it at an angle to loosen it up. When you get one broken loose, do the other side. When both are broken loose, continue to remove them the rest of the way. Now that you have the bolts out, cut some slots in the top of them for easy installation.
If you can cut slots in the top with the ignition still in, go for that. Sometimes that option is hard to do too. As for the door locks, there is usually just a little clip holding them in. They are pretty easy to remove once you get behind the door panel.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 09-06-2007, 08:03 PM
BLU CIVIC's Avatar
調整器
Re: Need some help
you guys are awsome
i emaild hime back to see if i can come get it and he said he won't be there , but to take whatever i want think i'll be getting an extra distributor
The name's Adrian
2011 CR-Z - Stock
Old 09-08-2007, 12:24 PM
BLU CIVIC's Avatar
調整器
Re: Need some help
thanks for the help guys...i got it out...i used my Dremel to cut a notch
The name's Adrian
2011 CR-Z - Stock
Old 09-08-2007, 01:46 PM
Tony's Avatar
TLD Member #1
Re: Need some help
Cheater
Tony
Old 09-08-2007, 05:32 PM
BLU CIVIC's Avatar
調整器
Re: Need some help
well i got it hooked up and starts...just have to hook up the door lock
The name's Adrian
2011 CR-Z - Stock
Old 09-10-2007, 12:17 PM
wiseguy01's Avatar
wiseguy01 wiseguy01 is offline
Re: Need some help
door lock should be held in place with a clip but make sure u re-key them first.. just pull cylinder apart and pay atention to the tumblers each one has a spring. take ur key and put it in and look at which tumblers stick out. then rearrange the tumblers the best u can then file the rest off and oil up and close up save urself 40$..
