2000 Grand Cherokee - ENGINE LIGHT UP !
Help!!! recently the check engine light lits so I started changing all the spark plugs, ignition coil and change oil & filter but the light persists. When I just switch on the ignition, the engine light & the check gauges are on while the rest of the lights went off. I try to check all gauges and it seems that only the battery charger gauge is not moving. Experts, please advise should I replace the charger gauge or just leave it as is?????
Thanks in advance. Bobng
Re: 2000 Grand Cherokee - ENGINE LIGHT UP !
Does the check gages light stay on when to engine is running? I dunno if it is just 96-98's but does the key thing work on 00's? the engine light means emissions so try to get it scanned. My bet is O2 sensor.
ASE Master Certified before the age of 20 Current Cars: 2001 Chevy Silverado 1500 Z71 5.3L 1996 Acura Integra LS B18 1.8L Past Cars: 1990 Buick Estate Wagon 5.0L 1987 Chevy S10 2.5L Tec Four 1995 Pontiac Grand Am 2.3 Quad 4 1996 Jeep Grand Cherokee Limited 5.2L AWD 1991 Ford Tempo L 2.3L 1992 Buick LeSabre 3.8L 1997 Buick Century 3.1L 1996 Lumina APV GT 3.4L 2006 Ford Escape 3.0L XLT |
When the CEL ( check engine light) stay's on it is because the computer has found an error somwhere in the system it could even be the transmission or something else. Take it to a local shop or even Autozone or something and have them hook it up to an OBD scanner to find out why the light is on. DO NOT just start swapping out parts.
Yes the key on off thing does work for the WJ models, the only one it does not work on is 1998 models.
turn the Key ON, OFF, ON, OFF, ON - the code will appear in the odometer field, P followed by 4 numbers - P????, (digital odometer equipped vehicles). On analog odometers you will have to count the CHECK ENGINE light flashes. Joe
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust). W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
