Old 09-05-2007, 07:35 PM
95DodgeAvenger95's Avatar
95DodgeAvenger95 95DodgeAvenger95 is offline
Send a message via AIM to 95DodgeAvenger95
A/F ratio's......?
ok, i turned up my boost to 14psi, ppl say its save to run at that. on the stock fuel system. i have an apexi turbo timer that has an A/F ratio on it, but it only goes into the ecu for the o2 sensor, so ik its not accurate but, its telling me when im under alot of boost that my A/F is like 10.1 or so. is this really bad? i do have an aftermarket boost gauge so ik its only 14psi. ne info would be great, sorry if this is in the faq i looked and didnt see anything in there.
Black 96 3000Gt Vr4 58k mi, H.H.H. Data logger, RPS MAX, Big16G/14b Combo, FMIC, AEM EUGO, Greddy EBC, SAFC II, 560's, hotwired 255lph, not cats, Solid motor mounts, Faze boost gauge, Apexi turbo timer, full exhaust with 3" ICH Single shot Catback, K&N Air Filter, Front upper strut brace, T-Case Bracket, AC delete, Meth injection, NGK stg 1 colder, 8k HID'S.
AIMING FOR 500+AWHP at ips dyno.
Old 09-05-2007, 08:32 PM
Hotshot8792 Hotshot8792 is offline
Re: A/F ratio's......?
I bet your turbo timer is set up to use a wideband O2. Tapping off your ECU gives you narrowband, which is completely useless in tuning heavy acceleration.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 09-05-2007, 08:53 PM
Thanks but it is safe to run 14lbs on the stock system correct? ik ive seen it but can never be to sure. thanks man
