Old 11-20-2002, 10:01 PM
Dx18704 Dx18704 is offline
Send a message via AIM to Dx18704
z6$$$
HOw much would a z6 engine cost
Old 11-20-2002, 10:15 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
Motor
Normally you can pick one up for around $500. I'm also looking for another one to play with. Time for a new project.
Old 11-20-2002, 11:24 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Hit up your local junkyard.
I found a D16Y8 at mine for 900 bucks. They had 3 other ones just sitting on their shelves, and I could've got one of them for alot cheaper, but the one I wanted had less than 8000 miles on it, so I figured the extra $ was worth it.
Old 11-21-2002, 09:20 AM
motor
I was looking through classified ads and a found a 98 D16y8 for $400 + shipping.
Old 11-21-2002, 02:48 PM
the y8 and z6 whats differnt
Old 11-21-2002, 03:29 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
slightly different combustion chambers...slightly different intake mani...that's what I can think of offhand. the z6 is out of the 92-95 and the y8 outta the 96-98. the swap is the same with each...
SOLD!
Old 11-21-2002, 03:38 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
D16Z6
1590cc
4 cyl, 16 valve
SOHC VTEC
9.2:1 c.r.
Power: 125 bhp @ 6600
Redline: 7200 rpm
Torque: 106 lb-ft @ 5200
D16Y8
1590cc
4 cyl, 16valve
SOHC VTEC-II
9.6:1 c.r.
Power: 127 bhp @ 6600
Redline: 7200 rpm
Torque: 107 lb-ft @ 5500
things to consider when you do the swap. a p28 ecu (approx $150) is the most efficent way to swap. with the ecu you should get a wiring conversion harness (approx $150). i would definately work that into your budget. i wasn't very happy with the pm6 (88-91 Si/EX) ecu + rpm switch route. p28 ecu runs smoother. just thought i'd mention it....
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 11-21-2002, 06:25 PM
Bleebdat Bleebdat is offline
Send a message via AIM to Bleebdat Send a message via Yahoo to Bleebdat
A little off topic from the whole discussion, but if u have an hf or si u might consider just putting a z6 or y8 head on ur existing engine, they can usually be picked up for 200 or less.
Old 11-21-2002, 09:18 PM
kris's Avatar
kris kris is offline
Off playing with fire.
There is a nice y8 gude head on ebay.
Old 11-21-2002, 09:31 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
I picked my Z6 up from a local junkyard, for $600 including the flywheel, dist. and wiring harness form the whole car...didnt really need it. but its nice to have that much wire now.....
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 11-21-2002, 10:37 PM
kris's Avatar
This guy --> [email protected] has a z6 with 60k on it for $500 shipped.
Old 11-22-2002, 01:19 AM
civicracer_1990's Avatar
civicracer_1990 civicracer_1990 is offline
I have a dx and converted to MPFI using the pm6 ecu then bolted the sohc v-tec head off a 95si (d16z6) and it went together quite smoothly...runs great doesn't overheat nothing.....if you're doing it on a dx d15b2 then you need the vx timing belt and if its on a d16a6 then you need the ex/si timing belt...simple....and its a pretty healthy increase in hp...for now its ok...saving for a b16a1
"Faster and Faster until the thrill of speed overcomes the fear of death" Dr. Hunter S. Thompson
