Old 09-05-2007, 04:23 PM
CorvDazed CorvDazed is offline
Exclamation 97 grand am gt obd-II codes
I recently bought a car from a private seller and everything seemed fine. Just recently I noticed the engine will occasionally "rev" sparingly when in park or nuetral. Also when I accelerate the car jumps forward. I immediately thought of misfires so I took the car to an Auto Part dealer and they checked my onboard computer system. It came out with 2 errors:
History DTC P0300
Random/Multiple
Cylinder
Misfire Detected
MIL NOT REQUESTED
Since IGN NOT RUN
Since Clear P/F
and
History DTC P0341
Camshaft Position
Sensor A - Bank 1
CKT Range/Perf
MIL REQUESTED
Since IGN NOT RUN
Since Clear P/F
Any suggestions. I already did some internet research about the misfire and I know where the spark plugs are and which bank but nothing of the camshaft sensor or its location. If you could reply to this thread or email me at: [email protected] it would be greatly appreciated
Thanks!
Old 09-06-2007, 09:16 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: 97 grand am gt obd-II codes
Welcome to AF !
Random misfires... typical, check the plugs, wires, coils, ignition control module(ICM), if they havent been replaced recently.
Could also be an injector faulty or its wiring.
The po341
Test the crankshaft position sensor.
Its located in the pass side of the engine behind the crank shaft pulley. You can follow the wires up to the top of the motor and test from their.
I dont have the exact spec on this so you might look into a cheap manual for your car.
Might check this link its for a 99 ga but it should be very simular to your 97.
Crankshaft position sensors -Testing & Replacing On 99-00 Grand Am's
Good Luck
1999 Grand Am SS 3.4 OHV
