Gages in Dash
I was wondering if anyone with a 2004 GMC Sierra is having problems with their gauges in the dash, because the gauges on my 2004 GMC Sierra is starting jump and not working sometimes, please any suggestions to solve this problem, please e-mail me at [email protected]. Thank you
Re: Gages in Dash
Check for wiring and the plug at the dash.
Re: Gages in Dash
Re: Gages in Dash
The one that plugs into the instrument cluster.
Re: Gages in Dash
Re: Gages in Dash
The part with all of the guages on it is called the instrument cluster.
Re: Gages in Dash
GM has a notorious issue with their instrument panel clusters not working correctly- 2003 to 2006 trucks are usually victim to this. The problems i've seen are primarily the speedometer needle sticking, movement of the needle being very notchy/rough, or completely inoperative while all the other gauges DO work. Other times, it will be stuck at say 50 mph while you're sitting still, and then it keeps incrementing when you start driving and gets stuck at 120 mph. Cycling the key on-off several times will usually bring the speedo needle close to zero again.
If this is your issue, then your instrument panel cluster (the odometer/speedometer/gauges assembly) needs to be replaced. There are problems with the stepper motors that control the needles being mechanically stuck. The other issue i've seen is that on startup, the entire gauge display is completely inoperative (absolutely nothing works), but other times, everything is fine. This is a different issue than the one above. This problem of all gauges being inop intermittently can usually be corrected with a software update that the dealer can perform. (free if it's under warranty, probably an hour labor if it's out of warranty). |
Re: Gages in Dash
Hello fellows,
I've got about the same problem on my GMC Sub'99 C1500. Lately the oil gage started flickering down to "0" and at the same time light "check gages" came on. So it is intermittently on and off, not constant as of yet. Oil changes as usual: 3500-4100mls, no skip; engine sounds normal. I stop by at Autozone and let them check. They found O2 sensor misreading(???). So I assuming it is may be the same cluster soldering issue as one that I fixed in my Neon'95 a couple of weeks ago by re-heating some points on the cluster. At the same time and also kinda randomly I have some rattling sound, like small teeth plastic gear rattle. And nothing goes wrong with the truck by now(knocking on wood). So if anyone experienced something like this I'd like to see resolution. Happy driving to everyone! |
Re: Gages in Dash
The problem is most likely your stepper motors. They can be replaced if you are skilled at a little delicate soldering. I fixed mine and saved about $400.00 vs. replacing the cluster. I ordered all 6 motors on E-bay for ablut $35.00. Contact David at http://www.speedometerrepairguy.com Hope this helps.
Chop |
Re: Gages in Dash
Thanks Chop,
I've checked the store but have not call David yet. I've search eBay - nothing appears for my year and make. The rattling is pretty annoying now, plus today something dies. Yesterday "CES" comes to the cluster but car where driving as usual, then in a second halve of day the saign has gone, so I was thinking it's cold start or I've checked battery - ok, now removed the alternator and heading to Advanced AutoParts. I'll post how things are rolling. Thanks. |
Re: Gages in Dash
There is a recall on this...
Mike 2010 GMC Sierra SLT E. Cab Z71 All Terrain 2009 Cadillac CTS4 3.6L AWD Performance Sedan |
Re: Gages in Dash
Mike,
Thanks for the information. I am pretty sure about call them. Getting back to C1500 death. Alternator were checked ok, so I dive down and took starter out. Advanced Auto guy shows me some insignificance in gaining under load, so verdict: dead. Ok, $104 with core exchange. Started with a bit chewing sound and in 2-3 minutes dies again. So I check the cables, put some protective grease over, started again - works ok. Driving second day normal. Thanks for everyone for their participation. Happy miles! |
