Old 09-05-2007, 11:05 AM
yaz4real yaz4real is offline
Noisy Bearing - Supercharged
1999 Buick Park Avenue Ultra Supercharged
The bearing on the pulley driven by the belt is very noisy. Can the bearing be replaced instead of changing out the entire air unit?
Old 09-05-2007, 02:21 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Noisy Bearing - Supercharged
You should have an Eaton M90 Gen3 blower (supercharger) and yes the snout bearings are replaceable without having to replace the complete unit. Also, a good idea to replace the snout seal and the coupler. Also, just to be clear are you sure it is not a noisy idler or tensioner pulley? Companies like ZZPerformance sell Eaton supercharger parts.
Timeslip 08/12/06
AF Community Guidelines
Old 09-05-2007, 03:26 PM
I have isolated the marbled noise coming from the snout on the Eaton.
I certainly appreciate your quick response and lead to where parts can be obtained. It is amazing to see instructions available on websites to complete this project in the garage.
Only concern is whether my standard puller kit will complete one of the steps in removing the inner bearing. All other tools seem to be standard.
I understand a new coupler makes sense to purchase.
Bearings and seal $30
Coupler $30
SC Oil $15
Old 09-05-2007, 06:20 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Wink Re: Noisy Bearing - Supercharged
This sounds more like the coupler than a bearing. Remove the drive belt and rock the pulley back & forth to see if it has any play.
Old 09-05-2007, 06:43 PM
BNaylor's Avatar
I agree Bo. A rattling sound is typically the coupler. Same noise I had a few years back in my L67 GTP. I replaced it with the improved one from ZZP. However, since the snout has to be removed I installed new snout bearings and a seal. I had an auto machine shop press out and install the bearings. Cost around $40 for labor.
To the OP, you will need s special SC pulley puller. A standard type will not work. I use a Pulley Boys brand which I purchased new. May come in handy later.
Also, on the SC oil make sure it is GM Supercharger Oil only. Part number 12345982. Two bottles which are 4 ounces each.
Timeslip 08/12/06
Old 09-05-2007, 07:03 PM
HotZ28's Avatar
AF Moderator Elite
Thanks Bob for the additional info. BTW, I just happen to have the info on the "pulley puller" at my finger-tips. Click Here
Old 09-05-2007, 08:21 PM
BNaylor's Avatar
And thank you kind sir.
Timeslip 08/12/06
Old 09-06-2007, 03:10 PM
As follow-up to the above, the Eaton M90 blower ( supercharger ), is spun by its own belt. Besides the pully on the snout of the M90 are two idler pullies located to the left of the ignition coils and just right of the battery. To remove the belt to this assembly, there must be a tensioner.
Two questions.
Would the main tensioner and the serpentine belt have to be removed to remove the belt providing services to the M90?
Where is the tensioner for the M90 service belt?
I did read it is unlikely for me to service the snout because of the special puller needed.
Thanks..
Old 09-06-2007, 03:14 PM
BNaylor's Avatar
Just relieve tension on the belt at the tensioner/pulley and the belt will slip off the pulley.
Snout removal procedures:
http://www.rollingperformance.com/snoutrebuild.htm
http://www3.sympatico.ca/aepa/blowerinstall.html
You do not need to remove the main serpentine drive belt unless you decide to remove the alternator which sometimes helps for easier snout removal.
Timeslip 08/12/06
Old 09-09-2007, 11:28 AM
Great diagram/ photo. Thanks for the information. Very much appreciated.
