Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-05-2007, 11:32 AM
eclipse787 eclipse787 is offline
taking the motor and tranny out of my 95 eclispe gs
i'm taking the motor out so i can rebuild the motor and swap the automatic tranny with a manual one. just want some pointers and tips to what problems i'll run into. also is there a way to get the drive shafts out without taking the wheel hubs off?
thanks tony
Old 09-05-2007, 11:35 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: taking the motor and tranny out of my 95 eclispe gs
I believe I unbolted the lower control are and that allowed me enough room to move the axles out the way. Also make sure you take the speed sensor out before pulling the axles out or you will break it.(Not sure if this is true on the autos) Its really not hard and pretty straight forward other than that.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-05-2007, 12:20 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Manual to auto tranny swap is 100x more work than you think it is. It's more than just a simple tranny swap with some shifter cables, you need to get a different ecu, clutch lines, resirvoir, clutch, etc...it's not worth it bud, just sell your auto and buy a manual.
And like silvr said, unbolt the lower control arm and steering arm and then the hubs should swing enough to get the axles out.
95 Talon TSI AWD
97 Eclipse GST
Old 09-06-2007, 11:51 PM
any body know if its easier to take the motor out the bottom or the top of the car?
Old 09-07-2007, 11:35 AM
caniborrow50cnts's Avatar
caniborrow50cnts caniborrow50cnts is offline
Send a message via AIM to caniborrow50cnts
well, i see that you have 2 threads for the same exact topic...but as far as the swap, a friend of mine didn't use a different ecu, it had to just be reset. it is easier to drop the tranny from the bottom since it isnt that tall and there is nothing below it, after you easily remove the bottom mount. if you plan on pulling the engine out, definately easier with a crane from the top. it is still somewhat easy to pull the motor out from the bottom, with the help of gravity, but you will still find it extremely difficult to install it this way.
72 Beetle - trashed
88 Escort EXP - dumped
92 Talon - sold
97 Eclipse RS - still own
99 Eclipse GST - still tearing up the asphalt
Old 09-07-2007, 11:56 PM
ok, this morning i hooked up the boom on my bobcat and lifted it out the top. everything went pretty smooth, other then the fact that i forgot about the fuel line and wrecked one of the hoses. but not bad being this is the first itme i've ever pulled a motor... now for the auto to manual conversion and finding parts. wish me luck.... apparently i'll need it
Old 12-16-2007, 12:05 AM
Luke Home's Avatar
Luke Home Luke Home is offline
Originally Posted by eclipse787
ok, this morning i hooked up the boom on my bobcat and lifted it out the top. ....
Did you leave the transmission on the motor when you pulled it or just pull the motor first?
Is it easier to pull the trans separate from the motor and remove it first from the bottom and then remove the motor from the top?
Or is this easiest to remove the trans and motor as a unit from the top?
1998 Bonneville SE 156,000+, Miles, Running Good So Far
1999 Camry LXE 105,000 3.0 V6 (1MZ-FE Engine), A541E Trans.
1997 EAGLE TALON ESI 2.0L L4 SFI DOHC 16V (Project Car - 140K)
Old 12-16-2007, 07:01 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
I dropped mine from the bottom along with all the steering components, axles etc still attatched. Took 5 hours. Easy enough to do if you have clearance underneath the car.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
