Old 09-05-2007, 09:39 AM
chickmag11 chickmag11 is offline
01 f150 small v8 won't start
oil, coolant, abs and check engine lights on, even with no key. motor cranks but will not start. has about 130K miles - been a great work truck. i know the oil is low. is there a fail-safe "no start if oil is low" on this truck? no info in owners manual. (coolant level is ok.)
thanks,
mike
Old 09-05-2007, 06:16 PM
Torch Torch is offline
Re: 01 f150 small v8 won't start
All those lights point to some kind of gross failure, I would hook an OBD-II box up to the plug under the steering wheel and pull the codes out of it, they should tell you what is wrong.
Old 09-05-2007, 10:45 PM
more info - my son had a great idea to disconnect the battery - wait then reconnect. Now it will start! Dash lamps stay on, but I think I'll take it to a shop.....
Thanks,
Old 09-18-2007, 01:42 PM
Update -
Shop said wires deep inside steering column - they've seen it a few times before. Replaced steering column w/ used - all working OK now.
Hope this helps someone in the future...
