Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-04-2007, 10:55 PM
mydelsol mydelsol is offline
please help, boost problems
I have a 90 tsi awd and its acting wierd. When I start it up, it will seem normal, idling at about 1800rpms til its warm and my boost guage will read boost. But after about 3 minutes, it wont read any boost, only vacuum. Then it will just not move at all and stay at about 20 vacuum. My guage is hooked up correctly and I have swapped another working guage in and had the same issue. I've tested for leaks and fixed the seals on my throttle body shaft but still have the same issue. I'm two hours away from home in college and its killing me in gas to try and fix it. Any help is appreciated.
1993 del sol s
1990 Eagle Talon Tsi Awd
Old 09-04-2007, 11:36 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Re: please help, boost problems
Well, I'm not sure about your car, but mine will go up to about 1500 rpms at start up and then down to 1000. Once it warms up it's at 750-800. Mine stays at around -20 vacuum all the time at idle. When i step on the gas it usually goes to 0 vaccuum and boost. Around 2300 rpms is where i start seeing boost. This is with a 16G.
What you have described sounds normal, according to my car. The bad gas mileage may be due to something else. Any CEL's, or weird readings on your data logger?
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 09-05-2007, 12:16 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
How long has the problem been doing this, or has it been doing it since you got the car/installed the gauge? It may be hooked up wrong.
95 Talon TSI AWD
97 Eclipse GST
Old 09-05-2007, 02:21 AM
When I first start it up and drive I will see about 5psi of boost max. Then after about 3 minutes of driving, I won't get any boost at all and the guage will read 20 vacuum and not move no matter what. I don't have any CEL's, the only odd ready on the logger is when at WOT, my o2 volts is always .02 or .00 From what I have heard and read, at WOT the o2 volts should be much much closer to .90 Oh and I'm getting some knock too. I'm not getting bad gas mileage that I know of, because I haven't drove this car much at all, I've probably put 200 miles on it since I bought it in Febuary. I just have to drive home to work on it.
Ever since I got my guage installed I have had this problem, but I may have had it before because the stock guage is only an estimate from the ecu. I have tripple checked the installation of the guage, I put it in based on what I see from this sketch. http://vfaq.com/index-main.html thanks
Thanks for input.
1993 del sol s
Old 09-05-2007, 11:26 AM
Does the boost gauge correlate with how the car is acting? ie. You step on the gas and the car takes off but the boost gauge goes crazy, or you step on the gas and the car has no boost? Sounds like you have more than just one problem here, and I think they're all working together to really mess things up. When was the last time you did a tune-up?
95 Talon TSI AWD
97 Eclipse GST
Old 09-05-2007, 12:45 PM
When I step on the gas right after I start it, the car goes and the gauge will move and seem normal, from an idle of about 20 vacuum to boost of about 5psi. But after 3 minutes, I can floor it and it will stop showing boost and only vacuum. It acts like its stuck at 20 vacuum, but I know its not the gauge itself because i tried a different one.
Thanks for input.
1993 del sol s
Old 09-06-2007, 01:19 PM
What consists of a tune up?
1993 del sol s
Old 09-06-2007, 02:05 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Does the car have a boost controller?
A tune up consists of the following for the most part:
Replace the fuel filter
Change the spark plugs and examine wires
Adjust the ignition timing.
Check belts.
Check fluids under the hood and replenish.
Replace the air filter
Adjust the clutch.
Check the battery
1991 GSX 2.3 Stroker
Old 09-06-2007, 09:39 PM
Have you done a boost leak test ever?
95 Talon TSI AWD
97 Eclipse GST
Old 09-07-2007, 12:54 AM
I do have a boost controller, but it has not been installed.
I have swapped the wires and spark plugs.
I have checked the belts and fluids.
I just installed a new clutch.
I just got a new battery.
I haven't messed with the fuel filter, ignition timing, or got a new air filter.
I ran the boost leak test and only found the leak at the throttle body. I have since then fixed it and found no other leaks.
Thanks
1993 del sol s
Old 09-07-2007, 10:53 AM
defiancy's Avatar
I'm just reading over your posts and you never say if it's effect performance (atleast that I can see) or if it's purely the guage itself. IE When the guage is reading just VAC is the car lacking alot of power? Or is it running like normal and the guage is the only thing messed up?
Old 09-07-2007, 11:07 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
It sounds more like a gauge problem. Is the gauge mechanical or electric? If its mechanical you might want to check the vac hose that goes to it. I know that if I twist my boost gauge just a little the line hits the pod and it wont read right. It will get stuck in vac or not go over like 10.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-07-2007, 11:39 AM
Well I don't know for sure. Since I have bought it in February, I have only put about 200 miles on it and it hasn't changed any in how it drives. It seems fine to me, I can feel it pull harder around 3k, but then again I haven't rode in a stock turbo dsm. I'm going to say the gauge is mechanical.....it uses vacuum line. I don't have the gauge mounted because the problem first occurred when it was mounted so i unmounted it to swap a different one and to check the connection. If the line was messed up though, the gauge would not just work for the first minute or so and then stop working because the line was messed up would it?
Thanks
1993 del sol s
Old 09-07-2007, 12:24 PM
defiancy's Avatar
Thanks
Not necessarily.
On my old DSM GST I had a POS guage on it, and often it would do pretty much exaclty what you were describing. The problem was that the vac line that went into the back of my guage wasn't seated proberly. When I would first start the car the guage would be fine, but after a few minutes of running (and subsequent vibration) The guage would drop and read nothing.
I highly suspect the problem lies in the vac line itself. Either it's not seated on the guage or on the T or there is a leak somewhere in the system.
If there was a major leak in the system the car would be very slow and sluggest. Since you are telling me that the car responds and pulls harder at abotu 3k. (about max spool for the stocker) It leads me to believe that you may be fine to drive the car around like normal. I just wouldn't install any mods until you can get the guage figured out.
Old 09-07-2007, 02:43 PM
Ok but what do you think about my logger showing .02 for the o2 volts when at WOT? This website says it should be in the upper 25% http://www.pocketlogger.com/index.ph...am=o2&type=dsm
Should I get a new sensor?
1993 del sol s
