Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-04-2007, 09:35 PM
Ashley Eclipse99 Ashley Eclipse99 is offline
Engine swap
Has anyone done a V6 conversion on an eclipse? Can it be done? I have problem with my engine and if i need to i'll do a swap and wanted moe power. Does anyone know how it would work?
'99 Eclipse ( 10 year anniversary edition) ( non-turbo) And a toyota 4runner truck in progess.
Old 09-04-2007, 09:37 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Engine swap
No it cant be done. It would take way to much work and a lot of money to do. And you really wouldn't be much faster.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-04-2007, 11:55 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Engine swap
Just re-build yours with some forged internals and slap on a turbo. BAM! Insta-power...(Well, after the lag).
95 Talon TSI AWD
97 Eclipse GST
Old 09-05-2007, 06:32 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Engine swap
Picture may not be authentic but I found this in a thread awhile back. Take from it what you want, but the motor is from a 2000+ Eclipse and it's a V6.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 09-05-2007, 06:52 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: Engine swap
I guess the question would be, why the hell would you do that?
1991 GSX 2.3 Stroker
Old 09-05-2007, 07:06 PM
Re: Engine swap
That's got to be the biggest waste of time and money I've ever seen...you don't even net that much more hp. They probably did it for bragging rights.
95 Talon TSI AWD
97 Eclipse GST
Old 09-06-2007, 02:33 AM
MazdaX's Avatar
MazdaX MazdaX is offline
Re: Engine swap
eh..it's a joke..too much weight in the front added with a v-6 and no room for turbblows now.
2004 Mazda 6i
1997 Tahoe
Old 09-06-2007, 07:27 AM
<Lucci>gs <Lucci>gs is offline
Send a message via AIM to <Lucci>gs
Re: Engine swap
would be the best advice ^^^
(not trying to ride his dick im just saying)
99 Eclipse gs (1oth anniversary edition)
NOOO TTTTTTTTTTTTTTTTTTTTTTTTTTTTTTT!!!!
MOds-
Dropped (Eibach springs)
TRadesonic Cold air intake
Old 09-08-2007, 01:17 AM
MazdaX's Avatar
Re: Engine swap
No thermostat housing cap...wiring looks horrible. Wondering if someone just took out their blown motor and lowered in the 6 banger that they just by chance had laying about and made eveything look lined up..just a shot in the dark though...not to mention the battery isn't even hooked up...
2004 Mazda 6i
1997 Tahoe
Old 09-09-2007, 06:16 AM
Re: Engine swap
Well thanks for all the input, sometime down the road i need a different engine. I'm looking for a way to put a big engine in without a lot of work if anyone has any idea as to doing that i'd sure like to hear what you have to say.
Old 09-09-2007, 10:13 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Engine swap
There is no easy/cheap drop in V6 (or bigger I4 for that matter) for our cars. I dont know what one of those 3g V6's cost, but you would need the entire drivetrain, wiring harness, ECU, etc. By the time you got all that you would be pretty deep in it. Then comes the install labor, unless your have someone that can do it. Even still, its not going to be an afternoon or even a weekend project unless they have a pretty good idea of whats going on. What about when it gets in? That is going to mess up your weight distibution and whack out your handling, remember that suspension is set up for a 4 banger. Trust me, its not worth the time. If your motor is going out and you want a V6 that bad, just sell the one you have and get a 2000+ Eclipse.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 09-09-2007, 10:15 AM
Holset powered 420a
Re: Engine swap
Alot of people are dropping a 2.4 into the n/t eclipse. Its still a good bit of work but I dont think its that bad compared to other projects.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-09-2007, 06:58 PM
Re: Engine swap
Don't bother trying to swap a V6 in, just rebuild your motor and turbo it. Cheaper and easier...and you can get some decent power out of it if done right.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 09-10-2007, 10:53 AM
defiancy's Avatar
Re: Engine swap
This would be essentially be the same as swapping the 2.0 turbo motor in there. Being that they basicly are the same block with a different head.
Old 09-10-2007, 01:24 PM
Holset powered 420a
Re: Engine swap
Apparently its not, I dont know what block they use but from what I have read about it only 1 motor mount has to be changed. There is also alot of fabrication involved but not near as hard as a 4g63. Check it out on 2gnt
98 Eclipse GS Turbo
2001 BMW 325i - DD
