Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 09-04-2007, 08:05 PM
wrightrl wrightrl is offline
power loss @ check light
I have a 1993 toyota pickup, 22RE engine, the engine would not run except on 1 cylinder, had it at toyota for 4 days they said they could not figure out what was wrong. My brother told me to check the throttle body, it was heavly carboned, removed the throttle body, air chamber,intake manifold. cleaned them replaced them. Now I am having problems starting, have to start vehicle 5 or 6 times before it will run. After it warms up it hesitates and looses power on hills. Also the check light will not flash codes it just stays on when doing a manuel check. the check light goes out when the vehicle is started. Does anyone have an idea what is wrong.
wrightrl
Old 09-04-2007, 09:39 PM
Ramblin Fever Ramblin Fever is offline
Re: power loss @ check light
You've actually posted this in the Isuzu Rodeo forum.
BUT, I used to have the 22RE Toyota in an '85 p/up for 21yrs; so I might be able to help.
You didn't say how many miles?? Has the timing chain been replaced at all, I'm assuming you're quite a bit above 100k??
Has the truck overheated *at all*?? Even the slightest - does NOT take much to blow the headgasket on this engine, TRUST me, did it 3 times. If the head/block is cracked, this engine will run terribly.
If you can, respond back to this thread, as I don't visit the Toyota forum on this website much and I might otherwise forget about you.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 09-04-2007, 10:05 PM
Sorry about that, first time user, has never been hot, toyota dealer said timing chane good, compression, injectors and all emission sending ok. has 250,000 miles on vehicle
Old 09-04-2007, 11:15 PM
Timing chain good..in the sense of it has been replaced at least once?? If not, I can assure you it's wearing or worn out. Our truck lost a boat-load of power, even though the chain looked good.
My advise, if you're not working on this truck yourselves, get a 2nd opinion; and don't bank on just one compression check; check it again.
Things I would look at, again, double check tightness of the spark plugs/gap, distributor/wires, cat convertor - make sure it's not clogged, O2 sensor (I had only one on my '85; if your's has never been replaced, it's toasted).
How old is that thermostat & radiator?? - not saying these are reasons for running poorly, just double checking their age, as these parts are far past shot at 9-10yrs of age in this particular engine.
Also, did you replace the intake manifold gasket when you had it off?
1997 3.2L V6 Rodeo
Old 09-07-2007, 04:48 PM
Thanks for your help found a bad wire to the cold start injector starts real good now
wrightrl
