Go Back   Automotive Forums Car Chat > Chrysler > LHS
Old 09-04-2007, 05:02 PM
earthdog's Avatar
earthdog earthdog is offline
94 lhs fault code 54
My lhs won't start I ran the codes and only got #54 which is the cam sensor.
I bought a new one at Autozone and put it in, still won't start.
I thought maybe the tensioner for the timing belt broke again. Pulled the timing cover and everything is ok in there.
What are the chances I got a bad cam sensor from Autozone?
What else could be the reason it's not starting?
Old 09-04-2007, 07:42 PM
wayneo69 wayneo69 is offline
Re: 94 lhs fault code 54
could be a crank sensor some times the computer in the car cannot tell the differnce between the cam sensor or crank sensor and will throw a code for the wrong sensor you need to test the senor
Old 09-05-2007, 06:51 PM
earthdog's Avatar
I'll pull the crank sensor and have it tested. Thanks.
